Old 02-02-2018, 11:52 PM   #16
Mig
Originally Posted by Troutman View Post
I don't think you're going to replace that bearing regularly are you? It's not a set of brake pads.
For instance my 2.7 has circa 80k on it and it's 19 years old..still on the original bearing and clutch/flywheel, I know this because I have a FPSH from the PO. RMS was changed in 2000 under warranty.
Changing the bearing is not something to be taken lightly, it's a big expensive job and it can cause other problems bashing a new bearing into that precision part called an IMS.
On a car that's worth £5k I'm struggling to justify replacing what appears (and I know what that means) to be a perfectly good bearing with another product for £700 and the risk entailed with removing the old one and fitting the new one. Remember..these engines were not designed to have that bearing replaced.ever!
These bearings didn't fail very often (mine is 1%) and something else caused them to fail, lack of grease and no oil or misalignment, could be an unbalanced IMS, who knows!
No matter what I do, I can't win (unless I keep the car for another 10 years and it doesn't fail and I save £700.. big deal!)
Thanks for the help anyway.Much appreciated.
Replacing the bearing with just another bearing doesn't fix the underlying issue of the grease in the bearing being washed away by the engine oil.
Yes, I will be replacing,mine on a regular basis. Plan is to replace it next summer. I do my own work and won't be bashing in the new bearing. (I've seen some of those videos on YouTube).
Yes, these engines weren't designed to have the bearing replaced, but that doesn't mean that it can't be done safely.
If you don't want to replace the bearing regularly, then I believe you need to invest in a solution whereby the bearing is fed by oil (DOF, EPS, or LN Solution).
Mig is offline   Reply With Quote
