Old 01-31-2018, 11:56 PM   #15
Troutman
Originally Posted by Mig View Post
I'll be replacing mine regularly. It's a maintenance item.
I don't think you're going to replace that bearing regularly are you? It's not a set of brake pads.
For instance my 2.7 has circa 80k on it and it's 19 years old..still on the original bearing and clutch/flywheel, I know this because I have a FPSH from the PO. RMS was changed in 2000 under warranty.
Changing the bearing is not something to be taken lightly, it's a big expensive job and it can cause other problems bashing a new bearing into that precision part called an IMS.
On a car that's worth £5k I'm struggling to justify replacing what appears (and I know what that means) to be a perfectly good bearing with another product for £700 and the risk entailed with removing the old one and fitting the new one. Remember..these engines were not designed to have that bearing replaced.ever!
These bearings didn't fail very often (mine is 1%) and something else caused them to fail, lack of grease and no oil or misalignment, could be an unbalanced IMS, who knows!
No matter what I do, I can't win (unless I keep the car for another 10 years and it doesn't fail and I save £700.. big deal!)
Thanks for the help anyway.Much appreciated.
Troutman is offline   Reply With Quote
