Old 01-31-2018, 11:51 AM   #11
JFP in PA
Originally Posted by Troutman View Post
So I removed the flywheel and there was some oil spread about the rear of the engine, some had gone out the gaps in the bell housing and covered the right rear of the engine.
Not really obvious if the IMSB flange seal was leaking but I reckon it might have been weeping. The RMS oil must fling out when the engine is running and spread everywhere.
Cleaned it all up.
So I locked up the cams after modifying the tools I got. Pulled the tensioners and pulled the flange.
As I thought the bearing looks perfect with no movement on it whatsoever...It looks like it was just fitted. Dual row.
So now I'm thinking leave it in, get a new type flange from Porsche and fit new clutch/flywheel, RMS ..job done....right?
Well I just don't know what the races/balls are like.probably like new no doubt.
Need to make a decision.
You spent all the time and effort to get at it because you were concerened, so it makes no sense to just leave it there as you are now about 10 min. from pulling it and replacing it with something that you can forget about for a long, long time. Choice is yours............
