01-27-2014, 09:35 PM
#21
Yep, if you want to run soft rubber you will need lots of neg camber in front. GT3 adjustable A arms are the way to go in a Boxster and will pay for themselves quickly in even tire wear and much longer tire life. This is the preferred method on Boxster Spec Race cars.
01-28-2014, 08:24 AM
#22
I have PSS9's set as low as I can go without spacers. I had it corner balanced with my weight in the driver's seat. Then I did my own alignment (made a framework and tools specific for this car). I also do not have any rubber in the rear suspension (adjustable arms, bushings not rubber, etc.).
I set mine at -1.25 degrees front, -1.75 degrees rear. Slight toe in both front and rear. If one goes 0 toe, it gets very touchy on the highway. With this setup, the bumpsteer was huge. Using a setup with multiple dial indicators and running the front suspension through its travel, I saw major toe out when the strut was compressed. That might have been good for certain tracks but was not good for the street. I created spacers to lift the steering rack away from the crossmember. With trial and error, I found the sweet spot. Now I don't get any bumpsteer throughout the travel of the front suspension. I think that it came out to about .4" thick spacers. Many people don't think about this when lowering a car, but it can make a huge difference in drivability.
2002 Boxster S with 3.4L Variocam-Plus Engine Swap
01-28-2014, 11:32 AM
#23
Originally Posted by 993innc
It seems the Spec racing guys can't use these parts though per the rules, so do they just get whatever they get by lowering and squeaking out whatever is allowed by the factory parts?
Boxster Spec allows the use of GT-3 adjustable lower control arms. This is how we reach >-3deg neg camber.
01-28-2014, 11:48 AM
#24
How can I set it up to drive 9/10ths without going crazy. That's what I'm after. I'm ok with a set if tires an event.
Install GT-3 lower control arms and align as discussed. This will provide the most bang for the buck and extend the life of the tires. You'll still overcook the outside portion of the tire at 9/10's but that is the tradeoff of not replacing the entire suspension.
I drove my 986 like this (all stock except for adj LCA's) for about 30 track days before I could outdrive the car and was ready for the full suspension upgrade.
01-28-2014, 03:34 PM
#25
Been looking around and have found some that don't use spacers. Elephant Racing has a set that is like a tie rod, it threads in/out instead of shims for adjustment. Any comments on that style either way? In theory, seems like the perfect way to go. Infinite adjustment without the need for shims or other "loose" parts.
As for the rear, simply lower the car. Camber is achieved via the concentric in the lower arm, I'll need to get new toe links, correct? Or do I have to replace all of the arms back there with adjustables?
Chris
- 1997 993 (started it all) - 1975 914 1.8L w/F.I. (restoring now) - 1985 "1958" 356 Speedster (cruiser until 914 is complete)- 2002 Boxster (future, ney...current! track car)
RENT ME FOR YOUR NEXT VACATION: www.vrbo.com/489534 or www.vrbo.com/499924
01-28-2014, 07:32 PM
#26
I can't see any significant difference between shimmed or threaded types of LCA's. Shims come in varying thickness and often require more than one to achieve the desired camber. Also, the shims are somewhat expensive and can be easily lost in a tool box. It is hard to tell but I wonder if the threaded type might be vulnerable to dirt/muck getting onto the exposed portion of the thread and might be hard to adjust after a few years. Pick your poison.
Yes, lower the car and you'll need new adj rear toe links. Most folks do not use rear adj LCA's.
01-29-2014, 05:43 AM
#27
I agree with you about the trash getting into threads. But A) I hope not to mow the grass with the car  B) those joints can't be any more susceptible than tie rods etc...
Could always wrap with tape to keep clean.
You've been a big help, thank so much. Now I just need to figure out who to buy from. As usual, spending waaaay more than I want to. Hate that I have the need to go fast
Chris
01-29-2014, 09:34 AM
#28
I use them on every car  every time.. It settles down the toe gain under braking by replacing those worn out rubber bits on our donor cars
FYI:
Unless you perform tire temps.. on your car.. at the track.. camber settings are *only* guesses. I have drivers that heat their tires evenly with -3.6 on a shaved RA1, then I have guy's who heat the tires evenly with -3.2 on the same tire.
Camber is driver and track dependent. I don't run the same camber on the right rear at Willow Springs that I would run at CA. Speedway. The track design heats the tire differently. You see this in pressures also. You cannot run the same cold starting pressure in the left rear at WSIR as the right rear. You will burn down the left rear
All good info coming from group!! The toe gain explanation is one of the best I have seen online!!
Also: Raising the steering rack in the front to correct bump = we've been doing this for years in 914's and 911's. Porsche Motorsports does this on ALL the RSR's  and I do it on Cayman's and Boxster's
01-29-2014, 10:58 AM
#29
Again, Brad I agree with what you are saying. I don't think I'm going to worry much about the track dependency. If I were arcing for $$ maybe
I just want to find a happy medium and go get my giggle on.
As for the raising of the steering rack, is there a benchmark to shoot for? At rest, are you trying to "level" either toe rods or some other functioning bit of suspension to know you've adjusted properly? I believe it was either my 993 or GTi back in the day, that this was an issue and I think the more level the toe rods were, the better.......same here?
This has been a great thread! Thank you all
Chris
02-02-2014, 07:40 AM
#30
This statement has been bothering me a bit. So, yesterday I checked my front bump steer. My set-up has aftermarket tie-rods, so I can shim the rod end at the upright rather than shimming the steering rack, but it's all the same.
My toe change was less than 0.1 degrees throughout the whole travel range with no shim adjustment. I haven't compared the tie-rods I am using to the OEM tie-rod dimensions, so it could be some difference there. The only other thing I can think of is that I am using a lot less caster than stock, so perhaps the caster change also has an effect.
I guess the moral is there is no short-cut to testing your exact configuration.
Kippis
986S
991S
Van Diemen RF97
02-24-2014, 05:06 PM
#31
So, thought I would update the thread. I ended up getting the RSS LCA's. Really wanted the Elephant Racing threaded type but apparently they are like hens teeth and of course I had just missed the last set and new ones weren't ready from the machine shop in time for my needs. I found the RSS only 3 hours from me.
I'm going to the alignment rack tomorrow after corner balancing myself (I have mechanical scales), so we'll see what values I get.
To recap, I've installed H&R coil overs front and rear (no spring rates from H&R other than progressive). I installed the LCA's with 13mm worth of shims each side, and am running 25 1/8"- 25 1/4" ride height to fender(center of hub) all the way around. Corner weights are in the optimum range as I saw posted here recently (6xx's front just over 8xx rear). In the rear the only replaced part other than shocks are the rear toe links.
I'll report alignment values once we get off the rack. If I don't get -3 camber up front, I think I'll wait for the rest of the alignment until I can get it. Will need to order more shims. I have a couple weeks left until VIR.....
I'll check the LCA's and steering rods for "level" or other, which may be another reason to jump down off the rack early. I know if either point north while static, that's bad and so I'll have to figure out how to adjust those issues.
Thanks everyone for chiming in, been a big help
Chris
02-25-2014, 04:24 PM
#32
At that ride height, you may find that your LCA's are "over center", which you obviously know is not optimum.
Good luck.
Kippis
986S
991S
Van Diemen RF97
02-25-2014, 05:31 PM
#33
Indeed I do know, and completely forgot to look this morning too.....had a meeting that interrupted hanging out longer with the alignment guy. But he didn't mention anything about it. I caught the need to worry about it as I was installing the LCA's, and with the spacer rings that come with them (to raise or lower the outer ball pin height), I think I got it taken care of. I can check tomorrow with the car in the trailer. Thanks for the renewed heads up.
I don't have the sheet in front of me, but I was able to manage (with 13mm worth of shims and a hint of honed out upper strut holes), just shy of -3 degrees camber. -9 degrees caster and a hint of toe front. Camber in the rear was about even with the front, and a hint of toe. I'll post actual numbers tomorrow. I didn't dial back the rear camber simply because I felt with my narrower rims and slicks, I thought it best to leave the added help keep all the rubber on the road. You're welcome to chime in
Chris
02-26-2014, 04:39 PM
#34
For your review (and comment if you must  ) my alignment specs. Camber is maxed out all the way around with the simple mods made. Alignment guy says camber increases (to the negative) by .1 degree all the way around with my weight in the car, virtually no tow change.
LCA's all the way around are nice and level, so I'm good there. I think I'm set up to at least run 8-9 10ths  will know in 2 weeks
Chris
02-27-2014, 01:17 AM
#35
550 Anniversary
Not much to comment on except the rear looks like it has more potential to be worked on. Whether it's good or bad depends on what tyres you are running and what handling balance you want to achieve.
02-27-2014, 10:03 AM
#36
Maybe it's just me - but that alignment doesn't seem like much of an alignment to me. The numbers are pretty off on both sides.
Here's an old alignment sheet from my old TT. I asked for these specific numbers and as you can see - they provided them exactly as specified. The car had camber plates and adjustable rear control arms.
Maybe i'm just picky - but if I'm going to pay for an alignment - I want them to do an actual alignment to my specifications.
02-27-2014, 04:34 PM
#37
Well I'm not exactly sure how comparing a completely different car applies? I have been told here and by others, that the values need to be as close to -3 camber etc as I can get as a starting point to work from.
These values are maxed out as you see it. These aren't arbitrary values, they are all the car could give me for the parts I altered.
Chris
02-27-2014, 05:00 PM
#38
I understand where you are coming from, but some things don't look right to me either.
That right rear looks like too much negative camber and too much toe-in. I am guessing from these rear end camber vs. toe numbers that your rear end is lowered to the point that you cannot reduce the camber any more, and you are stuck with too much toe-in at the rear. You may need to raise your ride height slightly to get back into a good adjustment range.
For the front I like to run absolute zero front toe, but to each his own. It's usually not a big deal, but I think these cars naturally have a bit too much caster. If you have the adjustable bushings in the center of your GT3 arms, you can adjust out some of that caster. Sometimes this helps if you are having problems with really wide front tires rubbing on the fender liner. I also have a theory that reduced caster can help with that stupid power steering overheating issue, and seems to help bump steer.
I'd take it back, even if it meant another iteration with corner weight adjustment.
One more thing on that -3 deg negative camber thing: If you are running NT-01's, I think this is really more camber than is optimum based on tire temperatures and wear patterns I have experienced. If you are running HoHo R6's or A6's, yes you definitely want the -3 degrees. Dunlops seem to like close to -3 also. I can't say for sure on others, but generally the stiffer the sidewall, the less negative camber a given tire needs.
Good luck.
Kippis
986S
991S
Van Diemen RF97
Reason: One more thing
02-27-2014, 11:57 PM
#39
550 Anniversary
That's what I was trying to say except a little less blunt  I have had my geo done and it is to within 1 or 2 minutes accuracy across the axle. Some will say you won't notice it but if you are paying for it and it is relatively easy to achieve, why wouldn't you do it?
02-28-2014, 02:57 AM
#40
Doug, I'm running Yoko slicks on 8" rims all the way around. Everyone I talked to told me to max out negative camber. I have adjustable toe links in the rear, that right rear may be a bit much, we'll see. I can tweak it at the track if it proves ugly. As for caster I was also told these cars really like as much caster as possible, and it was the alignment guys opinion that with more right turns typically than left, this should work just fine.
It's a starting point if nothing else and will hopefully be a lot better than stock suspension and alignment and street tires  As long as it feels safe, I'm good. It's just a DE car and I'll be using it as more of a rolling billboard for my beach vacation rentals (getting a wrap) than a full on race car so.....
Does seem weird to me that the right side of the car gets higher values than the left, wonder how that could be?
Chris
