For your review (and comment if you must
) my alignment specs. Camber is maxed out all the way around with the simple mods made. Alignment guy says camber increases (to the negative) by .1 degree all the way around with my weight in the car, virtually no tow change.
LCA's all the way around are nice and level, so I'm good there. I think I'm set up to at least run 8-9 10ths
will know in 2 weeks
