Originally Posted by 993innc
To recap, I've installed H&R coil overs front and rear (no spring rates from H&R other than progressive). I installed the LCA's with 13mm worth of shims each side, and am running 25 1/8"- 25 1/4" ride height to fender(center of hub) all the way around. ![Smilie](http://www.986forum.com/forums/images/smilies/smile.gif)
At that ride height, you may find that your LCA's are "over center", which you obviously know is not optimum.
Good luck.
