05-25-2012, 05:40 AM
IMS/Clutch job this weekend!, couple questions
I'm tackling the Pelican IMS retrofit and clutch job on my Boxster this weekend, and have a couple questions.
1) I don't have a flywheel lock, is there any other option?
2) Do you guys recommend jacking up the front and back of the car?
3) I've read through countless write ups but does anyone have any words of wisdom?
I'll keep everyone posted on the progress!
2003 911 C2
NASA HPDE Instructor
05-25-2012, 06:03 AM
I wonder why you choose the Pelican IMS upgrade vs the LN Engineering version?
I'll do mine in 5,000 miles when I hit 60K, or at the next clutch job, which ever comes first.
Just curious how you decided one way or the other on the 2 different IMS upgrades available.
05-25-2012, 06:41 AM
While the flywheel lock is a relatively inexpensive and useful item, it is not critical to getting the job done; it just makes it quicker and a bit easier, particularly if it is a one-man job.
If you can get the entire car up in a level position, you would be better off. But it can still be done with just the back up.
Take your time, read and follow the LN directions (I am not a fan of using setscrews to hold the shaft).
05-25-2012, 07:40 AM
If you chamfer the edge of the aligning hole on the flywheel, it goes on easier.
98 boxster
82 280sl parts for sale
05-25-2012, 09:22 AM
Good luck! My hat is off to anyone who replaces the IMSB as DIY.
Take some pic's and post as you make progress.
05-25-2012, 11:01 AM
Moderator
Truegearhead,
If you could post pictures of your clutch job and ims that would be amazing. I am wanting to replace the clutch on my car myself, but have found all the write-ups somewhat ambigious and hasty. Best of luck!
05-25-2012, 04:15 PM
1) You can make a lock yourself. Go to the local hardware store and get a piece/bar of steel (needs to be 8" long or so) and drill two holes. One hole will be big enough to bolt to the motor, the other hole slightly larger than the flywheel/clutch alignment pins. See attached photo.
2) Consider having the car level, it will make it a little easier aligning the bearing when you install it.
3) Don't drink any beer while doing this job.
Jäger
300K Mile Club
05-25-2012, 04:48 PM
[QUOTE=Jager;291609]1) You can make a lock yourself. Go to the local hardware store and get a piece/bar of steel (needs to be 8" long or so) and drill two holes. One hole will be big enough to bolt to the motor, the other hole slightly larger than the flywheel/clutch alignment pins. See attached photo.
What about German beer?
05-25-2012, 04:55 PM
Good thing you picked a long weekend - there are a lot of parts to take off and put back.
I suggest reading the Pelican Parts write up in 101 Projects before starting. It has some helpful photos. Then take pictures as you pull the gearbox out to note the direction of the components, and double check during re-assembly. There are plenty of nightmare stories where people put the clutch plate in the wrong direction or something and then no clutch after all that work.
Oh, make sure you have a 12 point triple square socket head before getting started for that one odd bolt on the bottom left side of the gearbox. I had one in my toolbox, but still had to machine my tool before using it due to the limited space behind the bolt.
Kippis
986S
991S
Van Diemen RF97
05-25-2012, 06:53 PM
Yea, that triple square bolt got me, I was not ready for that one. You will need something similar to what is pictured below (triple square bit and box end wrench). Also, most of the transmission (trans axle) to motor bolts are different, you will need to keep track of which bolt goes where. Label or number them as you remove them.
Jäger
300K Mile Club
05-25-2012, 07:01 PM
Only after the bearing assembly is mounted correctly in the end of the Intermediate Shaft... Then it's time for a cold one!!
Jäger
300K Mile Club
05-26-2012, 04:10 AM
I put mine up on four jack stands. Once you get the rear bumper and muffler off there was plenty of room. If you have an air ratchet that will make getting the axel bolts off much easier.
Chris
87 944S brought back to life
05-27-2012, 11:22 AM
If the 02 3.2 have a clutch cable can it be adjusted?
05-27-2012, 02:15 PM
Can you just pin the crankshaft at TDC to hold the flywheel or will the pin shear when you apply torque to the flywheel bolts.?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
05-28-2012, 11:47 AM
Crazy Austrian
No cable no adjusment
Crazy Austrian 007
http://www.ws-ab.com
06-05-2012, 09:00 AM
She's been sitting here for two weeks now! THe IMS replacement is complete, drive axles are rebuilt with new boots, and the transmission is installed. Now I'm stuck on the two broken exhaust manifold bolts. I've tried everything under the sun PB blaster, freezeoff,welding a nut to them, etc. I've finally decided to go ahead and drill them out. The member "insite"'s post on his 3.4L swap as well as some as PMs has been a huge help. I'm following his lead and using a Quickcenter with slow increments in bit size. I've always rebuilt a drill press to drill up which hopefully will help me a bit
2003 911 C2
06-05-2012, 03:13 PM
Damn, I wish I had that kind of room in my garage...
06-05-2012, 05:58 PM
Did you try heat?
2002 TT
06-06-2012, 03:37 AM
Anybody used one of those inductive heat guns yet? I'd like to know how they work...
2001 Boxster S 3.6L, Zeintop
