Old 02-23-2022, 08:21 AM   #1
try rotating the piece 45 deg & standing it up vertical to print. Should be able to print that as a single piece even with an Ender 3. May need need supports, but most likely not.
For ABS 20% infill should be more then good enough but I wouldn't go higher then 40%
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 02-23-2022, 08:37 AM   #2
Rob175's Avatar
So.....once installed, the cups used must be larger at the top than at the bottom, since there's nothing supporting the bottom of the cup?
IF so, (don't get me wrong, your work is excellent) but I think it could be problematic to take the cup out and drink while driving. Could be difficult to grip the cup's "lip" to remove it IF the cup's rim sits too close (ie: low) to the circular ring that supports the cup.
But since you're probably designing it for YOUR OWN USE and have a specific cup in mind. As a commercial design, it might not be as flexible for other cups.
Still EXCELLENT work and a nice personal solution.
98' Boxster
Rob175 is online now   Reply With Quote
Old 02-23-2022, 10:13 AM   #3
There is a bottom support for the cupholder. It's an "L" shaped piece that goes into a slot in the back of the cupholder ring. That's what I was talking about when I said I didn't have the bottom support installed when I took the pictures.
In this screenshot from tinkercad, you can see the bottom supports and the slot they go into. They fit in so tightly that they need nothing to hold them in, and Hulk couldn't pull them back out.
Tweetdriver63 is offline   Reply With Quote
Old 02-23-2022, 11:37 AM   #4
Is this how you meant?
https://www.thingiverse.com/thing:5260159
Old 02-23-2022, 06:55 PM   #5
Sent you a PM. Link doesn't work
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 02-24-2022, 05:11 AM   #6
That's weird. When I click on the link, it works just fine. Oh well.
Old 02-24-2022, 07:45 AM   #7
1998 Boxster Silver/Red
Link didn't work for me.
1998 Porsche Boxster
Old 02-24-2022, 09:01 AM   #8
The link still works for me on my computer. However, it doesn't work when I click it on my iPhone.
By the way, does everybody have that gap between the upper dash and the center, or is my car just weird that way?
Old 02-24-2022, 10:03 AM   #9
They all do.
Did you set the thing as public or private?
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 02-24-2022, 11:34 AM   #10
They all do.
That could be the problem. I had only used the "share" link. I have now published it. That might make a difference.
For everybody: I will publish the entire set once it's done, which should be in the next few days.
Old 02-25-2022, 07:19 AM   #11
Personally I would make it a 1 piece model for each cup vs 2 piece. Print with supports, it's why they exist. 1 piece is more secure then 2 pieces.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 02-25-2022, 08:20 AM   #12
Got them finished, and they're pretty good, if I may say so myself. The tops of the bracket arms have kind of a rough texture. I somehow managed to accidentally print them without supports, and that's how they came out. I don't want to sand them, because I don't want to make them thinner and weaken them. I think I'm going to either print cap pieces to cover them or use a bit of bondo, sanded and painted. I'll try the printed cover pieces first.
The bracket doesn't need anything to help hold it in place between the dash parts. It wedges in there securely as is.
They're a little bigger than a normal 12oz can.
I've only tested them with a few different size cups. I know they won't fit the big cups from Sonic. The smaller bottom part of those cups fits in, but the larger part prevents them going far enough down into the holder to be secure. I don't drive around with those things much anyway. Only if I'm just transporting them home. Medium sized styrofoam cups fit, but are tight (Sonic cup on the right). They fit a medium paper cup perfectly (Subway cup on the left).
When they're not in use, they fit easily in the armrest.
Old 02-28-2022, 01:13 PM   #13
Now on Thingivers!
Now published here on Thingiverse.
Old 03-02-2022, 05:16 AM   #14
Nice job, and thanks for sharing them!
Radman is offline   Reply With Quote
Old 03-02-2022, 05:25 AM   #15
I could entertain purchasing it pre-fabbed... since I don't own a 3-D printer.
How much would you charge for the item, absent shipping? Could it be made in a color of choice? Thanks.
Old 03-02-2022, 06:02 AM   #16
I don't want to go down that rabbit hole, specially since I'm pretty new to this 3D printing stuff. However, I also shared this project in the Facebook Porsche Boxster Owners Group, and one of the owners there is preparing to offer it to the community for cost+shipping. Filament comes it all kinds of colors, so if you're able to get him to make you one, you'll just have to work that out with him.
If you're on Facebook, join the group and when he gets started you should see him posting about it.
Old 03-02-2022, 06:16 AM   #17
Here's a picture with the covers installed. Gives it a much more finished look and probably adds a little strength too. (Yeah, I know. I really need to clean out the car. Probably doing that today, if I feel well enough. Yesterday a pickup truck towing a trailer full of cows pulled over in front of me on the highway, and just then, one of the cows with its back end up against the rear of the trailer took about a 5 gallon piss. It's probably not good for the paint to leave it too long before washing it!)
Old 03-02-2022, 07:15 AM   #18
If you have someone make these make sure it is with ABS not PLA. PLA will warp & break.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 03-02-2022, 07:18 AM   #19
I made mine with ABS. The guy on the Facebook group says he plans to use PETG. I'm not having him do it. All I did was share it, and the link to it on Thingiverse. What people choose to do with it is up to them, right?
Old 03-02-2022, 07:25 AM   #20
Dont have facebook so not sure what someone there is going to charge for costs + shipping. Just sliced this and it came to a cost of about $5 in materials for ABS. If it were me though I always add in the cost of maintenance of my printer, factor in a print failure rate of 20% (low end with ABS) and time/effort. I would put something like this with someone elses design of around $20 + shipping. if I were doing it.
I am going to print one to see how well it does and if I have to do anything different then just print. Looks like to print everything each one is going to be 15 hours total.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
