Old 09-04-2022, 11:18 AM   #501
WALDMEISTER
BRAN's Avatar
X-MAS is coming...
Old 09-04-2022, 12:42 PM   #502
JBauer's Avatar
X-MAS is coming...
Well HO HO HO. 🎅
Old 10-01-2022, 09:26 AM   #503
WALDMEISTER
BRAN's Avatar
They finally offer orange...
Old 10-01-2022, 09:40 AM   #504
WALDMEISTER
BRAN's Avatar
Porsche offers officially Otto Fuchs wheels (Fuchsfelge) for the 993/996/986.
I still remember when they were offered for the 993, how I contacted Otto Fuchs and together we got them with TÜV on my 986. So I kind of paved the way for the 986.
NOW Porsche offers them in high glossy black, gentled with a laser engraved PORSCHE logo (somewhere, I could not detect it on my scan).
PORSCHE, if you read this somehow...I would like a 18" set in black
Old 10-01-2022, 09:43 AM   #505
WALDMEISTER
BRAN's Avatar
another interesting find...
Old 10-09-2022, 09:08 AM   #506
WALDMEISTER
BRAN's Avatar
Yeah baby...the Pegasus is flying again!
Old 10-09-2022, 02:29 PM   #507
BruceH's Avatar
I like it!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 10-10-2022, 01:00 AM   #508
Hm...
https://www.ebay.de/itm/363122591207
Old 10-10-2022, 03:56 AM   #509
WALDMEISTER
BRAN's Avatar
Hahaha...
If I had a cutter/plotter...I would have done those stickers myself.
But there is (i hope) a tiny little detail, which I can't "unsee".
The Porsche "original" is not outlined. That alone is worth 80 bucks (taking nail sissors and cutting those away takes at LEEEEAST 1 hour...times man power cost).
Just kidding, we're Porsche nuts. There is no substitute.
Old 10-10-2022, 04:21 AM   #510
KevinH1990's Avatar
Your car is a great resource.
KevinH1990 is offline   Reply With Quote
Old 10-16-2022, 06:50 AM   #511
WALDMEISTER
BRAN's Avatar
the legendary 2.7 engine
it can't get any more RETRO with a 2.7 and a Pegasus on the side
911.559.015.03 "2.7" + 911.559.107.00 "back plate"
I care for details, 'cuz they tell the story.
Old 11-06-2022, 06:20 AM   #512
KevinH1990's Avatar
They were being offered on ebay Germany a few years back, it was kind of a rare find. As far as I can remember, 3 of those were sold as journeyman's pieces - "new" (to become a carpenter?).
Quality is absolutely fine...but I had to work on the inside to make it fit properly.
Now guess what? I found on ebay today: Maybe it was one of those being sold, "used" now.
search on ebay for: Porsche 996 986 Handbremse Handbremshebel Echtholz
BRAN,
The seller of the handbrake graciously agreed to ship to the U.S.
My original plan for installing the handle was to remove the console and swap in the handle assembly. This process requires dying the leather on the handle assembly black and disassembling the center console. I have experience with both dying leather and removing the center console and I expect no issues with either processes.
The challenge I have is that the wood handle is missing the piece of leather trim that finishes the area between the handle and the rest of the assembly. I will need to remove that piece from my existing assembly.
Do you have any suggestions for removing this part without damage? It appears that I could pry it up with a plastic tool, but I want to confirm that.
Based on the photos of your car, it appears that you may have twisted off the old handle and simply slid the new handle on your existing assembly. I'm concerned that if I do this, the existing handle will break because it is already cracked.
I will appreciate any guidance you are able to provide.
Thank you
Old 11-06-2022, 01:28 PM   #513
WALDMEISTER
BRAN's Avatar
Wow, nice! Those are really rare pieces.
As you mentioned, I only removed my old leather handle and re-installed the wooden one. And that was tricky enough, as they hardly come of and the fitment of the wooden handle was sub-par. Lots of filling was necessary.
How about contacting the seller, he might have an idea what happened to the top piece and how it came of. Btw. mine is just standard plastic, yours is leather...i guess i need to upgrade that, too (once you know, how the disassemble it) ;-)
But honestly, I could image, that it might be possible to push it back a few mm and then it can be lifted up. Just a guess, if I look at those screws.
Old 11-08-2022, 02:51 AM   #514
WALDMEISTER
BRAN's Avatar
Interesting, it has a wooden button?
As I remember brute (dosed) force was necesarry for the (dis/re-)assembly, as those handles slide on grooved rails (within the handle). The wooden one's were subpar, so I had to use tiny precision files to shape those for a perfect fit. Once it sits, it sits.
I could imagine taking it off again will harm the fitment and you have to use glue later on for a permanent fit.
To put it in a nutshell: Go the route with reinstalling that missing upper piece.
You might want to ask in the general segment, if someone (Woody?) could check that on some spare brake handles.
Old 11-08-2022, 09:19 AM   #515
The handle has to come off first.
I think fixating the complete handle by the hole and pulling the wooden handle grip with a hankerchief or something that gives you grip will help will help to pull it off.
Maybe heating up the wooden part of the handle will also help? Not too hot. Maybe 70-80 degrees celsius.
Here are some pictures. You can see, that the carbon part is overlapping the alcantara part.
Old 11-08-2022, 07:03 PM   #516
KevinH1990's Avatar
Thanks. Your photos and information are helpful.
Old 11-11-2022, 11:41 AM   #517
KevinH1990's Avatar
I prepared the assembly for installation
I dyed the leather black. The dye requires application of several light coats. I allowed about an hour for each coat to dry.
Coverage by the first coat is minimal:
The second coat shows progress:
The third coat provides almost complete coverage:
I also removed the leather trim from my existing handle. Although it was already black, I applied dye because it had faded from years of sun exposure. I wanted to ensure an exact match.
Finished product - I applied 4 coats of dye to the assembly and 2 coats on the trim piece:
I will allow the dye to cure overnight and install it in the car tomorrow.
Old 11-17-2022, 01:13 PM   #518
WALDMEISTER
BRAN's Avatar
I need those tires, an adjustable ride height and ready is the Boxster Dakar.
it was about time
Old 11-19-2022, 05:32 AM   #519
KevinH1990's Avatar
I ran into a barrier when I attempted to install my new handbrake. If anyone has suggestions for removing the handbrake lever from the emergency brake assembly, please respond to this thread:
I need to remove the handbrake lever from the e-brake assembly
Thanks,
Old 03-04-2023, 04:30 AM   #520
What was/who was your source for the top (not side) 3-piece decal stripes?
Thanks, Mike
stagewex is offline   Reply With Quote
HTML code is Off
