Old 03-18-2015, 02:07 PM   #2
Possible accusump oil line location - the unused oil port plug on top of the engine. Does that sound workable or does it have flaws such as:
  • The outlet is too small or large to support the desired flow.
  • The outlet is in a place where if the oil pressure dropped and the accusump had to add some oil "bad" things would happen.
  • The routing of the oil line down to where the accusump would be wouldn't work (the tunnel would be one place to mount)
  • Other???
Otherwise it seems like it could be a good place to put the oil line for the accusump, and avoid having to lose some clearance down with the oil filter hanging down low due to the sandwich plate. (and save a few bucks on the sandwich plate too )
The oil port I am talking about is the one used for the DOF feed go to page 3 or 4 from the end and also some folks have mounted an oil pressure or oil temp gauge in this location:
Oil temp sensor
Does that sound workable?
Steve
The reason the oil is routed to the oil filter is that it goes from there through relatively large oil passages to feed the rotating assembly, which balls up quickly at high revs and without oil. Feeding oil back into the heads requires the oil to go though small passages backwards before it sees the rotating assembly, which simply could take too long.
