On my '06 cayman I used a spin on adapter from LN, then a sandwich adapter from Canton (22-566 single port), and a napa 1042 oil filter. I also have the old style deep sump from mantis, which hangs pretty low. The 1042 filter is maybe 1/8" below the oil pan. There is a smaller oil filter available, but it was SO small I opted not to use it. If you are a member of cayman register there is a writeup there with some pics. I put the accusump in the tunnel under the car rather than in the trunk.
