Old 03-18-2015, 01:43 PM   #1
steved0x's Avatar
Possible accusump oil line location - the unused oil port plug on top of the engine
Possible accusump oil line location - the unused oil port plug on top of the engine. Does that sound workable or does it have flaws such as:
  • The outlet is too small or large to support the desired flow.
  • The outlet is in a place where if the oil pressure dropped and the accusump had to add some oil "bad" things would happen.
  • The routing of the oil line down to where the accusump would be wouldn't work (the tunnel would be one place to mount)
  • Other???
Otherwise it seems like it could be a good place to put the oil line for the accusump, and avoid having to lose some clearance down with the oil filter hanging down low due to the sandwich plate. (and save a few bucks on the sandwich plate too )
The oil port I am talking about is the one used for the DOF feed go to page 3 or 4 from the end and also some folks have mounted an oil pressure or oil temp gauge in this location:
Oil temp sensor
Does that sound workable?
Steve
Old 03-18-2015, 03:07 PM   #2
  • Other???
Oil temp sensor
Steve
The reason the oil is routed to the oil filter is that it goes from there through relatively large oil passages to feed the rotating assembly, which balls up quickly at high revs and without oil. Feeding oil back into the heads requires the oil to go though small passages backwards before it sees the rotating assembly, which simply could take too long.
Old 03-18-2015, 03:20 PM   #3
jsceash's Avatar
The kit comes with a remote filter and this was my solution. It posted some where on forum But here it is again
Currently use a Wix, 51060R on track
Old 03-19-2015, 07:08 AM   #4
steved0x's Avatar
The reason the oil is routed to the oil filter is that it goes from there through relatively large oil passages to feed the rotating assembly, which balls up quickly at high revs and without oil. Feeding oil back into the heads requires the oil to go though small passages backwards before it sees the rotating assembly, which simply could take too long.[/IMG]
Thank you!
Folks that are running an accusump on the boxster using the sandwich adapter (and not the remote oil filter), what oil filter are you running?
  • Wix 51042 (or equivalent) - combined with a deep sump it probably would not hang down much if any? With no deep sump it looks like it would hang down a little.
  • Some shorter filter, like Wix 51081? Looks to have virtually the same specs as the 51042 but just shorter in height, with a shorter change interval?
  • LN billet oil filter with washable media?
  • Other?
Steve
Old 03-19-2015, 09:11 AM   #5
Sandwich Adapter -part number or source?
And a follow up :
Anyone able to direct me to a source for just the sandwich adapter? Hopefully with a threaded inlet and outlet.
Old 03-19-2015, 02:15 PM   #6
Its a Canton product.
Lon Tusler
1999 996, Track Only #996
Everything Jake could upgrade, and more!
ltusler is offline   Reply With Quote
Old 03-19-2015, 02:41 PM   #7
On my '06 cayman I used a spin on adapter from LN, then a sandwich adapter from Canton (22-566 single port), and a napa 1042 oil filter. I also have the old style deep sump from mantis, which hangs pretty low. The 1042 filter is maybe 1/8" below the oil pan. There is a smaller oil filter available, but it was SO small I opted not to use it. If you are a member of cayman register there is a writeup there with some pics. I put the accusump in the tunnel under the car rather than in the trunk.
spendy is offline   Reply With Quote
Old 03-20-2015, 08:53 AM   #8
Thanks to both of you. Here is a link if others are interested:
https://www.cantonracingproducts.com/product/22-546/22-546----UNIV-OIL-COOLER-SANDWICH-ADAPTER-1316-16-2-58/
There are cheaper alternatives(Quality??) on Ebay. Some have 3 x 1/8"NPT ports that may be useful for DOF or an oil pressure gauge. Some are combos & AN8,others AN10.Just search "Sandwich Adapter LS1 13/16". Just guessing this would be correct .Please confirm before you buy.
