Old 03-09-2015, 12:01 PM   #1
Artist, 986S tinkerer
NewArt's Avatar
AirLift won't hold vacuum on drained system.
I drained some antifreeze in order to change the o-rings in my oil cooler. I Also changed one of the radiator fans so I was working up front as well. Everything is back together again but now the system won't hold a vacuum. I can't get the Airlift to go aboe 14 lbs. So before I start tearing everything apart again, how should I go about finding the leak? Any hints?
BTW, I replaced the tank 6 months ago, so it's not that.
