Old 03-09-2015, 01:43 PM   #3
JFP in PA
I drained some antifreeze in order to change the o-rings in my oil cooler. I Also changed one of the radiator fans so I was working up front as well. Everything is back together again but now the system won't hold a vacuum. I can't get the Airlift to go aboe 14 lbs. So before I start tearing everything apart again, how should I go about finding the leak? Any hints?
BTW, I replaced the tank 6 months ago, so it's not that.
Vacuum leaks are usually pretty noisy; try checking around where you worked with a mechanic's stethoscope while pulling a vacuum on the system.
