02-12-2015, 05:38 PM
#1
5 vs 6 speed pros/cons
I know the 5 speed has a lower final drive ratio.
And I know the 5 speed is much lower cost initially
This is for my 914 project so very light car. Will have around 250 - 300 HP.
02-12-2015, 05:57 PM
#2
6 speeds are known to have 2nd gear pop-out / synchro issues, also well known in the 996 series which uses the same transmission albeit inverted. Go with the 5 speed.
02-12-2015, 06:14 PM
#3
six speeds have reverse in the wrong place on the shifter! all the years of muscle memory have confirmed that fact to me. allegedly the six speed is a more durable gearbox, but I have not had any problems with my 5 speed so that is an unconfirmed rumor as far as I am concerned.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
02-12-2015, 06:19 PM
#4
6 Speed has one more speed than a 5, so more is always better.....right?
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
02-12-2015, 06:53 PM
#5
The 6 speed driveshafts are at a rather steep angle compared to the 5 speed. So the boots wear .The 6 speed is a very expensive/difficult gearbox to repair.Just do a search and you will find mention of very expensive tools and massive force required.Not a great diy proposition.
In your case the gearing of the 6 speed is unhelpful unless you plan to remove tree stumps with 1st gear :-)?Your car will be so light/powerful,the 1st gear would be somewhat useless except for generating tire smoke.
02-13-2015, 07:38 AM
#6
Track rat
300 hp may be too much for the lil 5spd which was only rated for 250 or so. It may survive with a good trans cooler. I do think the ratios are better for track work though.
02-13-2015, 07:56 AM
#7
1999 base
as a previous owner of a 01 boxster S with 75K miles 6 speed.
and a current owner of a 99 boxster base with 160K miles 5 speed
i'm telling you, go with the 5 speed. its a night and day difference.
02-14-2015, 10:37 AM
#8
Hey there Guys,
I have quite a bit of experience with both of these gearboxes, so I can answer some of the questions that have come up here.
The 5 speed would certainly work well for you. It is geared pretty low, but then so is the 6 speed. It is however far less durable than the 6 speed.
It really depends on which of the 6 speeds you decide to use though. There are two of them to chose from. The 986.20 and the 987.20 one is out the Boxster S and the other is out of the Cayman S.
If it was my build, I would try to find a good low mile G86.20, do the detent mod on it and rebuild it prior to installation. It is a very strong gearbox, and with the detent mod done along with the rebuild, it will be very durable. You will want to make sure to take care of the 1st and 2nd gear as much as possible, but 3rd -6th are pretty strong, and can be beat on without fear of breaking them. I would also recommend a good differential. My personal favorite is the OS Giken, but there are several out there to choose from.
Feel free to give me a call if you have more questions, I would be happy to discuss the pluses and minuses of your choices out there.
Erik Johnson
(970) 344-7761 phone
02-16-2015, 03:35 PM
#10
Run the 2.5 5sp. Want to upgrade later? Use the 987 BoxsterS 05-06 6sp. Shorter ratio's than the CaymanS 6 sp. I have multiple cars with 300-340hp through the stock 2.5 and 2.7 5sp transmissions. We can break them, but so can a 201hp 2.5. No need for coolers/etc. Cooling the trans does not stop the teeth from sheering off of 3rd gear
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
10-12-2015, 05:00 AM
#11
550 Anniversary
I have a 2004 986 S and want to investigate a lower final drive.
What are the ratios on the 2005/07 987S?
Brad - when you say use this box do you mean transplant the gear set or will the box just bolt up?
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
10-12-2015, 06:08 AM
#12
The 6 speed is "1" faster.
10-12-2015, 06:13 AM
#13
Rennzenn
What's the weight difference between the 5sp and the 6sp?
Rennzenn
Jfro@rennzenn.com
10-12-2015, 06:23 AM
#14
You have never driven an early 911.
You want to talk about a messed up shift pattern.
R 2 4
1 3 5
10-12-2015, 10:27 AM
#15
I think the 986 5-speed is about 50 lbs lighter than the 986 6 speed. the 987 unit is a bit in between the two. if I recall correctly from when I looked into it, the 986 and 987 6-speeds share the same slave cyls and hubs so are a relatively easy swap. the 986 5-speed is different. all have unique axles and shifter cable arrangements. you can use 5-speed axles with 6-speed hubs but will have less axle thread to nut on to. other than that, there are variations in the 986 5-speed gearing and flange dimensions over the years, and even more variation if you start looking at the interchangeable audi 012 units. the 987 boxster and cayman 6-speed also differ in gearing. also, I think that, in the case of these transmissions, mass is proportional to strength - the 986 6-speed is quite strong, the 987 unit less so, and the 5-speed is easiest to break. however, being lighter/smaller (shorter) they have better axle geometry than the 986 6-speed.
10-12-2015, 06:26 PM
#16
Porsche "Purist"
My 1998 3.6 has the original 2.5 5 speed, no issues, over 100K on the gearbox...
1987 924S. 2002 996TT. PST-2
10-17-2015, 04:42 AM
#17
What's the detent mod and what's the reason for doing it? I'm planning on running 400+bhp on a G86.20
10-17-2015, 05:55 AM
#18
still plays with cars...
Here's what I have read. The modified detent allows the 2nd gear selector to engage a bit more deeply, reducing synchro damage and gear pop out.
I fit one to the transmission because of a minor crunch on the initial 1-2 up shift of the day before the gear lube warmed up. That was 2 years ago, and it hasn't recurred since.
Six speed 2000 Boxster S
10-17-2015, 10:49 AM
#19
I installed the detention a few months back to address the same issue and it has not happened since.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
10-17-2015, 04:29 PM
#20
Rennzenn
The 6sp trans has a 2nd gear pop-out issue. I had to rebuild mine at 142k. I did the G-box detent, I'm at 180k no issues.
Rennzenn
Jfro@rennzenn.com
