Old 11-12-2020, 07:48 AM   #1621
The diagrams Paul posted are not quite right...the first one is to turn the AE's off when headlights are on and the second was for a more specific application.
This is the flash to pass relay diagram if you have original halogen high bulbs:
A little knowledge is a dangerous thing, sorry!
Old 11-12-2020, 07:50 AM   #1622
No worries, Paul!
The second one would work, but I think Tony has the single throw relay. I’m not 100% sure either, I guess.
Old 11-12-2020, 10:01 AM   #1623
amagalla's Avatar
IIRC, the LED AE ring is epoxied in, as well. It shouldn't be too hard to dig (dremel?) it out, though.
The AE on mine wasn't epoxied in. It was held in by the black retainer ring, which was epoxied to the lens that was epoxied to the aluminum base. The black ring and the lens were no longer epoxied so everything came out with no issues. We'll have to wait an see if the other one is like that too.
Also, to remove the nut, try some heat. Get a small butane torch and heat the post so you don't damage the reflector bowl. Careful, now...
I used wd40 and a heat gun, I got it to the point where the WD40 was smoking, and still no go. What I'm going to do is unscrew the assembly (with the lens, AE, and the high beam iris) off the post and leave the post in there.
Tony
Lapis Blue 03 Boxster S
Old 11-16-2020, 03:34 PM   #1624
Recently inherited a water-damaged 986 and brought her back to life. Now getting the mod itch and just stumbled across this. A shame Im so late to such an awesome upgrade. If they ever come back in stock, add me to the list (or if any other members have a set theyre selling, let me know).
preppyr6 is offline   Reply With Quote
Old 11-16-2020, 05:24 PM   #1625
Hey folks -- any thoughts about bolting the ballasts to the back of the light housing and having it live in the fender well?
beater986 is offline   Reply With Quote
Old 11-16-2020, 06:12 PM   #1626
That's the general consensus, it's in the pdf instructions and other posts within this thread. I's also what the factory did on the Litronic headlights.
Old 11-17-2020, 04:25 AM   #1627
I have a pair Particleweave converted for me. Some scratches on lens. I only track the car now so I want to sell.
Old 11-17-2020, 06:02 AM   #1628
If you're up for it you can also follow the basic instructions in this thread and make a similar pair of headlights using Bi-Xenon projectors like the Morimoto Mini. This is a pair I made last winter and then late this summer I finally got around to wet sanding, polishing and clear coating the outer lenses. I acquired a set of junk Litronics and some badly burned amber halogen lights. I used the Litronic reflector bowls and inner shrouds with the halogen housings. If you just use the halogen lights, you can get shrouds for the projectors similar to those Porsche uses on its current models.
Old 11-18-2020, 09:18 PM   #1629
Has anyone designed a mount for this yet?
Old 11-19-2020, 02:27 AM   #1630
No need. The ballasts always have at least one bolt hole for mounting. The headlight rear covers also have some unused bolt holes that just need to be drilled out. It’s all fairly self explanatory once you see it
Old 11-22-2020, 02:08 PM   #1631
That looks great. Im pretty handy so I may look into this further. Thanks!
Old 11-22-2020, 02:23 PM   #1632
Sent you a note on your profile
Old 02-17-2021, 07:55 AM   #1633
amagalla's Avatar
I was able to repair the light that came apart, and while I was in there, I removed the dead angel eye and replaced it with this:
https://smile.amazon.com/gp/product/B07CYV3CV4/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
The main difference is that it has a third wire that can power an amber set of LEDs. When voltage is applied to the third wire (to light the amber LEDs), a relay turns off the white LEDs until power is removed from the amber lights for a second. This allows it to flash the amber lights without the white lights coming until the flashing is done. I connected the amber lights to the turn signal light. When the turn signal is on, the amber flashes, when the turn signal is turned off, they white comes back. It looks really great. I went through the extra effort of applying a water proof coating on it. I'm in the process of doing the same thing to the other side as well (obviously).
Tony
Old 02-17-2021, 08:48 AM   #1634
BruceH's Avatar
Tony
Any chance of pictures and/or a video? Sounds interesting.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 02-18-2021, 09:03 AM   #1635
amagalla's Avatar
Next project is to re-polish the headlights.
https://www.dropbox.com/s/9cgmrp4rp8xzul3/20210218_095003.mp4?dl=0
Old 03-01-2021, 03:28 PM   #1636
CGT light kit availability
Just stumbled on this and as a recent 986/996 convert and just discovering the HID ‘upgrade’ in my 2002 996 less than desirable looking to install an OEM quality /look product
These appear to be duks nuts military grade
How where when can I source a set for 2002
996 (RHD and also an equivalent upgrade for 1997 986 (silver red)
Cheers from Oz
micheloals is offline   Reply With Quote
Old 07-05-2022, 06:05 AM   #1637
I'm resurrecting this thread to ask if anyone has an extra set of internal headlight lenses for the 1999-2000 996-style halogen headlights (1-piece internal lenses with a slot for the level indicator bar.) It appears @ParticleWave is no longer active on the forum, so I'm hoping someone else can help.
These are the style of internal lenses (luckily mine are not in this bad shape.)
Carlton Bale is offline   Reply With Quote
Old 07-05-2022, 02:05 PM   #1638
I have one complete bucket with a pretty nice lens for the passenger side. It's got the tiniest start of a burn mark that is only perceptible from certain angles. This picture is probably the worst, I could take a picture from a different angle and you wouldn't see any burn at all. I don't know how to remove the lens from the bucket and don't want to try and possibly break it. A USPS Medium size Priority Mail box would fit and cost $16.10 to ship. If you want to pay for shipping via PayPal or Zelle and you could have it. Send me a PM. Honestly though, if you're going to the trouble of opening up the headlghts, why don't you convert them over to bi-xenon projectors with a quality set, like the Morimotos. Here is a picture of the lens-
Old 07-06-2022, 02:40 AM   #1639
1998 Boxster Silver/Red
Not to derail the thread... but the name Particlewave struck me.
Does anyone reading this post have the install instructions for the SAI device he invented? Some of you will know what I'm talking about. If you could PM me those install instructions that'd be great. PW scrubbed all mention of the device's install. Thank you.
1998 Porsche Boxster
Old 07-06-2022, 07:25 AM   #1640
I looked into the RetorfitLab.com projector upgrade, but I don't like the "black hole" that exists because the main reflector was removed. I prefer a more factory look with the silver reflector bowl in place. Is there another option that enables this?
If there's not a more factory-looking upgrade, I think my only options are to replace the burnt lens or switch to factory Litronics. I'm not too excited about either due to cost and complexity.
