Old 11-12-2020, 11:01 AM   #1623
amagalla
amagalla's Avatar
IIRC, the LED AE ring is epoxied in, as well. It shouldn't be too hard to dig (dremel?) it out, though.
The AE on mine wasn't epoxied in. It was held in by the black retainer ring, which was epoxied to the lens that was epoxied to the aluminum base. The black ring and the lens were no longer epoxied so everything came out with no issues. We'll have to wait an see if the other one is like that too.
Also, to remove the nut, try some heat. Get a small butane torch and heat the post so you don't damage the reflector bowl. Careful, now...
I used wd40 and a heat gun, I got it to the point where the WD40 was smoking, and still no go. What I'm going to do is unscrew the assembly (with the lens, AE, and the high beam iris) off the post and leave the post in there.
Tony
Lapis Blue 03 Boxster S
