Old 11-22-2020, 03:08 PM   #1631
preppyr6
Originally Posted by PaulE View Post
If you're up for it you can also follow the basic instructions in this thread and make a similar pair of headlights using Bi-Xenon projectors like the Morimoto Mini. This is a pair I made last winter and then late this summer I finally got around to wet sanding, polishing and clear coating the outer lenses. I acquired a set of junk Litronics and some badly burned amber halogen lights. I used the Litronic reflector bowls and inner shrouds with the halogen housings. If you just use the halogen lights, you can get shrouds for the projectors similar to those Porsche uses on its current models.
That looks great. Im pretty handy so I may look into this further. Thanks!
preppyr6 is offline   Reply With Quote
