Old 11-24-2013, 03:48 AM   #121
Nine8Six's Avatar
<<--- see previous page for DSLR pictures of anodized colors
Old 11-24-2013, 03:52 AM   #122
Nine8Six's Avatar
How to connect the kit to your existing headlight's circuit:
Old 11-24-2013, 08:12 AM   #123
Fred, do the original high beams still work then after the solenoids are connected, i.e. are the solenoid wires spliced in? Or are they redundant and the only highs are from the projectors?
Old 11-24-2013, 08:23 AM   #124
You could, but that would be redundant...and the projector would block some of the beam anyway.
It would be similar to using a flashlight in daylight
Old 11-24-2013, 10:20 AM   #125
I left the chrome finish on the reflector bowls so that the halogen high beams would continue to work well. The problem with xenon is that it takes time for the bulbs to warm up, so they can't be used for flash to pass if they are off when flashed. I wanted to preserve that capability.
I wired a standard automotive relay across the low beam, with a diode across the coil as is common practice. The positive lead going to the high beam is cut and connected to the common terminal of the relay. The normally closed terminal of the relay goes to the bulb side of the high beam wire that was cut, and the normally open terminal of the relay goes to the projector coil. The other wire from the projector coil is grounded.
So it works like this - when the low beam is off and the high beam is flashed, the halogen bulb is used, as it was originally. When the xenon low beam is turned on and the high beam is flashed, the shutter is opened.
After running the low beam for 30 minutes, the ballast is at 91 degrees, and the front of the projector is at 132 degrees.
Sorry about the crummy picture. You can see the relay in the middle of the picture, on the right. It fits inside near the white adjustment knob, held in place with a small piece of industrial velcro.
MitchSF is offline   Reply With Quote
Old 11-24-2013, 10:42 AM   #126
kjc2050's Avatar
Wow. Beautiful work!!! Stunning.
Old 11-24-2013, 10:50 AM   #127
Nine8Six's Avatar
Norm - See above post from MitchSF. Brilliant isn't it. You'll get far better advice from both Particlewave and MitchSF than I can possibly give you on the conn-wise subject.
Personally, I went to lazy route and simply left the high beam's H7 lamp in there and connected the solenoid to it. Like MitchSF mentioned, flashing during day time is required and this H7 halogen does a good job for that. However, Particlewave is pretty accurate saying it will become useless in night time.
The projector xenon's high beam is brightning up the hell out of everything when the solenoid is activated (high beams ON). Brutal. Outperforms any stock 55w halogen's high beams so you shouldn't miss it too much and very possibly, forget all about old-halogen tech for the rest of your life as well
Old 11-24-2013, 10:55 AM   #128
Nine8Six's Avatar
MitchSF's idea, not mine. And Yes I agree it looks good.
Soon a lot of owners will have better looking shinners than mine unfair
Old 11-24-2013, 11:03 AM   #129
Projectors are brilliant! Wiring is high school electricity 101.
Mitch
Old 11-24-2013, 12:45 PM   #130
Simple, yet elegant solution Mitch! Love it!
Fred...sorry for the build delay. Finals at school and holiday prep has been killing my free time
Build starts in 6 hours!
Shouldn't take too long since most of the work is already done.
Old 11-24-2013, 12:59 PM   #131
Nine8Six's Avatar
Uh-oh. I was hoping you'd take your time.... sort of letting me think that my-kit-is-cool-looking for a few more weeks.
Seriously, I can't wait to see how the green devil eyes turns out. Knowing your skills and creativity, I believe you'll have a few more surprises as well
Old 11-24-2013, 01:07 PM   #132
As usual it's not that easy for us Canadians. We need the daytime running lights. I get the feeling I'm the first one of us to try to do this. If not, the rest of you Canuckleheads, please let me know!!
Old 11-24-2013, 03:39 PM   #133
I have something in the works click
I don't have DRLs, but wanted some form of running light, so I'm doing something completely unique. Mock ups of the idea look pretty sweet!
Stay tuned
Old 11-24-2013, 03:45 PM   #134
OK particle, you've got my attention!!
In the meantime, I'll get Fred working on my kit!
How does quasi gun metal grey sound on a Seal Grey Boxster, instead of the standard silver?
Old 11-25-2013, 02:05 AM   #135
PaulDash's Avatar
Here (in Poland) daytime running lights are required year-round. Most people just drive with their low beams on all the time.
How would your projectors work in a situation like that? Any overheating?
I have a set of clear lights that I have to polish up and was thinking of retrofitting your kit at the same time. I'm still not 100% clear on the procedure, though, so if you can please PM with the instructions.
PaulDash is offline   Reply With Quote
Old 11-25-2013, 06:43 AM   #136
Nine8Six's Avatar
Nice! Greetings from Shanghai Paul
Changing the xenon bulbs regularly will be your main concern. The manufacturer of the xenon bulb I am including in the kit rates them @ 2,000hrs. That said if you use your car 2 hrs per day, you are likely to need a xenon bulb refresh every two years (according to the manufacturer). In your case, I'd say changing them annually and they should perform at peak efficiency all the time. A pair of H1 Xenon bulbs (35watts ) will cost you a huge $20 each year. Not a crisis!
Bear in mind the complete assembly is made of aerospace 6061 T6 grade aluminum. That type of aluminum conducts heat about 2000 times faster than plastic (PE). The heat generated from the xenon bulb is not a problem and dissipated across the bowl (cast aluminum), the skirt and the bezel evenly. The whole thing effectively acts as a massive heat sink. The assembly runs at 45°C(min) 55°C (max) @ 60min operation. In Fahrenheit that would be 113°F(min) 130°F (max).
Ballasts can sustain the heat they are rated at which is between -40°C ~ 105°C (or 220°F). I've toasted a pair overnight in a enclosed environment (4"X6"X2" toolbox) and picked them up in the morning @ 54°C (130°F). So those passes my quality standards and comply with what the manufacturer swears by. A bad quality ballast can, and will, go up to 80°C ~90°C (175~200).
Regarding the DIY steps required to get this done, please let me know what procedure(s) you are not clear on and I'll do my best to explain in details.
Old 11-25-2013, 06:59 AM   #137
Nine8Six's Avatar
PM sent Norm. Incl gunmetal light grey color visual.... essentially the same as seal grey (very close if not a perfect match).
You get to make the hard decisions
Old 11-25-2013, 07:05 PM   #138
Sanding, sanding, sanding...
Those ridges in the bottom of the reflector are a PITA. 60 grit sandpaper speeds it up some, but I still wound up with 4 bloody knuckles.
Almost there.
Old 11-26-2013, 04:36 PM   #139
Beginner
Jamesp's Avatar
My headlights stink. They are yellowed, burned, dead halogens. even after polishing the outside, which was a vast improvement, the best thing that can be said about them is "disappointing". This is a super interesting thread, and everyone posting on the thread knows whats going on. As an outsider looking in, can you tell me what the heck are your plans for the headlights your sanding? Oh yeah, sorry about the knuckles.
Old 11-26-2013, 04:50 PM   #140
Haha! Thanks, the knuckles are recovering.
I'm sanding the reflective chrome finish off of the reflectors because I'm going to paint them black. Paint doesn't stick real well to that shiny stuff
It looks pretty slick all black with these projectors installed (see pg 3-4 of this thread). I'm hoping to be done by tomorrow, but holiday prep may cut into the project. Definitely will be done by Sunday...
Are the outer lenses on your halogens ruined also? The inner lens can be ditched with this upgrade
