Old 10-18-2017, 11:39 PM   #21
Originally Posted by AZ986S View Post
I admire what Chris Cervelli is doing for the dry sump solution, and I had read that post. The problem is that he does not say what the issue is, only somewhat vague statements on how some common fixes don't help, namely, Accusump, extended oil sumps, oil baffles and Dual scavenge pumps. No doubt the ultimate solution IS Dry Sump, but, to what the Radium King said, why did the X51 and all subsequent engines have an additional oil scavenging pump if that is not at least part of the issue? Also, how can an Accusump NOT help, even if oil is pooling in the heads? Accusump also adds a couple quarts of oil to the system, so that certainly helps to keep temps down. So, short of spending $20K on a dry sump system, I'll go with the "band aids" for now
I'm with you and your thoughts mirror the reasons I started the thread. I'm also with you on the cost issue, but if you follow the cost argument further...what if the most important factor is driving style and the band aids actually do nothing to stabelize oil pressure and are purely there for as a comfort blanket and to fill vendor's pockets? If so we might as well just stop after doing all cooling mods (confirmed) and just drive...We keep the money for a future rebulid. Unless the mods add power of course.
The reason I'm sceptical to the accusump is that I have read, and I suspect, it simply has too much lag to fill in the pressure dips. Also, all air bubble sucked in by the pickup, (or from pump cavitation due to high RPMs?)is already in the systen when the pressure drops and the only way to purge it is via the bearings. As Chris says it may help for extreme cases where the pickup continues to suck air for a longer period, but that is not what is causing pressure dips. If you have lost pressure for that long you have also lost your engine, in my opinion.
When it comes to the dual scavenge pumps they may be needed for other issues.In more powerful high-revving engines where the oil flow is higher. Pooling, backpressure and areation from the moving valve train come to mind. Anyway, they surely can't hurt our engine.
Chris states that the X51 baffles may work in the rear mounted 911s, but if the logs show the same pressure dips as before the installation in a mid-mounted engine it clearly does not alleviate the specific problem of pressure drop spikes in our cars, at least not in the tested engine.
Bebbetufs is offline   Reply With Quote
Old 10-19-2017, 12:20 AM   #22
Originally Posted by Racer Boy View Post
I did five track days last year, but only one this year.
There are two reasons I haven't gone to R-compound tires - I wanted to avoid the oil starvation trouble, and the cost. I'd have to get another set of wheels + the cost of the tires themselves.
What track do you run at in Norway?
I understand your reasoning. Thanks.
I mainly run at Rudskogen. It is mostely accelerating rights and stop-go lefts. One of the rights is high speed and severely off camber. Top speed braking while turning right down the steep hill, then hard acceleration back up the hill and into the S's. This is where I expect the problem to be worst.
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Old 10-19-2017, 12:22 AM   #23
Originally Posted by jsceash View Post
I have a hand built by me Frankenstein motor there is very little left that has not seen some modification. I currently have 40k on the motor rebuild. I don't think about it too much at the track. I do watch my videos and data logs carefully when I get home. I have 2 oil pressure gauges and an oil temp gauge, that I can watch on track, but don't watch more than a glance or so a lap. I run Dot 40 CAA or BAA Slick tires. I will see G's in the 1.6, 1.8 range on really good laps. I have added measures as the G's have increased through the years. My oiling, cooling mods go like this
1. Dual chamber AOS (motorsport AOS)
2. LN ceramic IMS bearing.
3. LN 1/2 Qt Deep Sump. with X51 stainless baffle.
4. Third radiator
5. 4" underdrive pulley
6. Accusump. 2 Qt. with remote filter.
7. 997 oil cooler.
8. Air to Oil cooler fan cooled.
9. Electric power steering pump.
10. Manual engine Bay Fan switch.
Nice mods and longevity.
Did you alter bearing clearances?
Would you mind sharing some of your logs?
1990 944 Turbo
Norway
Old 10-19-2017, 01:25 AM   #24
Just to add my two cents.
80% of my business is to the racing crowd. I spend a lot of time talking to these guys and a lot of them are removing the accusump system because it isn't reliable (pressure switch)and is just dead weight. Of course you also have a bunch of people who swear by them. I'm leaning towards the useless side even though I have one in my car. I do like the ability to pre-lube though. That's when it's working at least. One thing they all agree on is the baffling in the oil pan. I think they all either use the X51, aftermarket or modify a factory pan.
Now when it comes to Cervelli's drysump system. It looks to be a wonderful system and has proven itself on the race track. Chris races in WRL and I don't believe he's blown a motor since installing his system. For those who don't know. Guys race for 8-24 hours in the WRL series. They beat the living tar out of these cars and 100 hours seems to be how long a motor last with them. Except Chris! Other race teams who compete with Chris are installing his system. It's not cheap but it might pay off in the long run. Here's the his website boxsterdrysump.wordpress.com or you can call him at 303-809-6173
Woody
Old 10-19-2017, 04:06 AM   #25
Thanks for your opinion Woody. That's the final nail in the coffin for the accusump as far as I'm concerned. I have spoken to Chris, but I need to prioritize building a workshop. Maybe I'll buy his system in the not too distant future. In the meantime I hope my engine doesn't blow
1990 944 Turbo
Norway
Old 10-19-2017, 02:51 PM   #26
jsceash's Avatar
Hey Jsceash, did you notice coolant and/or oil temps lower after you installed the 997 cooler?
Last summer I was hitting 205 on a regular basis. The track outings this year I saw my water temp at 185 to 190. My oil pressure was stable with a 15 PSI drop at 1.4 and 1.6 G's on the passenger side head, and no drop on the sump.
On a side note I added the engine bay switch at the same time so it is hard to say how much each helped.
Old 10-19-2017, 03:03 PM   #27
jsceash's Avatar
My crank was balanced by a local service that builds 410 sprint engines. It was installed with stock Porsche bearings. My spinning weight is over 10 pounds less than stock.
I have shared videos with data on them but I don't know how to extract the data out of the video. I use a Garmin Virb XE with a Blu-tooth ODBII.
Old 10-19-2017, 03:13 PM   #28
jsceash's Avatar
I don't know anything about the dry sump. The solenoid supplied with the accusump is crap, if you have one get rid of it. Find a online supplier of a 1/4 SS solenoid with a edpm diaphragm. Or else buy the manual operating kit.
Old 10-19-2017, 04:02 PM   #29
Topless's Avatar
My 2.5L Boxster logged 100+ track days, many at ACS Fontana which is known to kill dozens of 986 motors directly due to starvation. My brother and I ran nearly identical cars and both were regularly at the pointy end of the BSX time sheet. We never killed a motor.
There are lots of gizmos, gadgets, and methods to attempt to resolve this and I don't know any that are 100% effective. Here was our strategy with success over nearly 200 combined track days:
-Run NT-01 tires which are good track tires but generate less lateral G forces than the 40tw R-Comps.
- X-51 pan
- Castrol 5w40 oil changed every 6 months
- Make sure the oil level was exactly topped before every session at hi G tracks.
- Complete the banked sweeper at max speed and stay well away from the rev limit as we downshift for the next corner. The idea here is that after a banked sweeper, the pan is nearly dry from hi G cornering so we let the car idle under full braking to allow for some refill and only blip to 4k on downshift at the last possible moment. Pinging the rev limit with a nearly empty oil pan is the best way to cavitate the oil pickup and score the main bearings, killing a nice flat six motor.
I can't say these methods will work for everyone but they certainly were effective for us in BSX class.
Old 10-19-2017, 04:35 PM   #30
steved0x's Avatar
I didn't say in my post above, I almost never go above 6500 RPM and typically shift around 6000-6200, exceptions are places like coming up to tower turn at Sebring (or other turns) where I don't really have time upshift because I would then immediately downshift so I wind it out a little but try never to go above 6500. I believe 6500 is the Rev limit on the 2.5 engine as well. It's just my philosophy. Am I losing time? Maybe...
Old 10-19-2017, 08:34 PM   #31
Steve. What you are saying makes a lot of sense and is very interesting. Changing driving style and remaining quick may be the most efficient (and most complex) mod there is. I'll have to study a map of your track to learn more.
Old 10-19-2017, 08:39 PM   #32
Unfortunately, a better solenoid won't help purge air that has already entered the pickup, which is what a pressure drop spike is. The air, or lack of oil, still has to pass by the bearings.
Old 10-20-2017, 06:59 AM   #33
AZ986S's Avatar
I use a 2 qt deep sump with horizontal baffle combined with a X51 style vertical baffle.
Hey Thstone, what brand is the horizontal baffle you have? Is it the LN Engineering one?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 10-20-2017, 12:25 PM   #34
not to answer for him, but thats the TuneRS one, also known as Pedro's techno sump.
Old 10-20-2017, 01:17 PM   #35
steved0x's Avatar
Yeah, then he added on the EBS X-51 baffle - more details in his thread (it is a big thread and many pictures are gone unfortunately due to photobucket...)
Spec Boxster Build
Old 10-20-2017, 01:33 PM   #36
truegearhead's Avatar
I’ve been tracking my car (VIR) with R compounds for years and in addition to track events have been completing up to 20 autocrosses/year. It’s been living this life for 7 years or so, with no extra cooling or oil modifications (stock cooler, stock baffle etc) and I’ve been running Mobil one (not the best). It’s never had a problem, it’s outlived most of my buddy’s non-Porsche engines. I don’t have any “tricks” I redline it, don’t pay any mind to long sweepers and don’t have any oil gauges. VIR doesn’t have any banked corners per day but the car does pull 1.28 Gs in hog pen due to the elevation change. This all being said it’s probably on fire as we speak...better go check on it
2003 911 C2
NASA HPDE Instructor
Old 10-20-2017, 01:53 PM   #37
@truegearhead. I suspect a lot of people do this and get away with it. People tend to talk about what goes wrong. If something works as expected they generally keep quiet, and nobody makes money on solutions that way either. Thanks. Then again, maybe your driving style is better for the engine. My plan for next season is to follow your example, with the exception that I do have some mods in place.
1990 944 Turbo
Norway
Old 10-20-2017, 02:02 PM   #38
Just for kicks. Here's a nice rendering showing tank sloshing and the effect of baffles.
The rendering is of course not directly comparable to an engine as it does not take the insane tornado of windage and the unbelievably rapid flow of oil into account.
Considering the pickup would be in the middle it seems clear that baffle higth is important. The effect of the baffles depend on enough oil being returned to the central space as it is sucked dry by the pickup. At high RPM the oil pump moves about 1 qt (0.9L) pr. second or more. The amount of oil that can be returned at speed into the central space, and how aereated it is, becomes just as important, if not more, than how well the baffles can retain the oil.
Another potential problem could be that it seems like large pockets of air may be introduced as the oil rushes back to fill the empty side of the tank. This may be why some report more spiking in oil pressure with baffles.
Oil flow numbers.
964 - 65L per minute
930 3.3L - 100L per minute (high performance engines from this era uses larger bearing clearances to aid cooling, amongst other things. They need a higher weigth oil and larger flow to maintain the same pressure.
GT3 RS - 83L per minute (clearances are tighter in modern engines so a lower weight oil may be used. This lowers the need for flow and increases efficiency)
3.8 RSR - 57L per minute based on one persons dyno testing.
Source: http://forums.pelicanparts.com/porsche-911-technical-forum/193700-oil-pump-rating.html
1990 944 Turbo
Norway
Old 12-13-2017, 03:14 PM   #39
Accusumps work great if you use the electric or manual valves. It's just 2 or 3 quarts of pressurized oil always available to feed the main bearings, pressurized by the oil pump. No lag, just pressurized oil. Stay away from the EPC set up where there is a pressure sensor that operates the solenoid...these have proven to be unreliable and can not deal with the wide range of oil pressures one sees on the track. The down side on this style is you need to remember to fill it EVERYTIME you turn the motor off and do it the same way each time so you can get consistent oil level readings.
titaniumdave is offline   Reply With Quote
Old 12-14-2017, 09:55 AM   #40
AZ986S's Avatar
So if I were to bypass the pressure switch that activates the EPC solenoid valve and just have a switch to turn it ON/OFF, would that work as well as the Electric Valve? I could easily test that just by some minor rewiring work, without physically removing the pressure switch. I like the EPC valve because it is a one-way valve and fills up the tank when turned off. I'm currently setting up my Race Capture and AnalogX system and hope to have oil pressure data at 2 locations: the standard bank 1 valve cover location, and also at the inlet of the remote oil filter (before the filter/cooler, after the oil pump). That is just across from where the Accusump feeds into the circuit (at the outlet of the remote oil filter). This should give me info on oil pump outlet pressure, and total pressure drop across the filter, cooler and engine bearings.
