Originally Posted by titaniumdave
Accusumps work great if you use the electric or manual valves. It's just 2 or 3 quarts of pressurized oil always available to feed the main bearings, pressurized by the oil pump. No lag, just pressurized oil. Stay away from the EPC set up where there is a pressure sensor that operates the solenoid...these have proven to be unreliable and can not deal with the wide range of oil pressures one sees on the track. The down side on this style is you need to remember to fill it EVERYTIME you turn the motor off and do it the same way each time so you can get consistent oil level readings.
So if I were to bypass the pressure switch that activates the EPC solenoid valve and just have a switch to turn it ON/OFF, would that work as well as the Electric Valve? I could easily test that just by some minor rewiring work, without physically removing the pressure switch. I like the EPC valve because it is a one-way valve and fills up the tank when turned off. I'm currently setting up my Race Capture and AnalogX system and hope to have oil pressure data at 2 locations: the standard bank 1 valve cover location, and also at the inlet of the remote oil filter (before the filter/cooler, after the oil pump). That is just across from where the Accusump feeds into the circuit (at the outlet of the remote oil filter). This should give me info on oil pump outlet pressure, and total pressure drop across the filter, cooler and engine bearings.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
