09-09-2024, 05:27 PM
#1
Swapping engines
My 986 suddenly started performing poorly — overheating, smoking, and a liquid that smelled like coolant was dripping out of the exhaust. I checked the oil and, sure enough, the dipstick was coated with a milky froth — oil and coolant mixed. I haven't done a compression test, but the symptoms pointed to a cracked cylinder or something equally unwanted.
Accordingly, I bought a replacement engine on eBay, another 2.7L M96, with 39,901 miles on it. The engine I'm replacing has clocked over 155,000 miles. The replacement cost me $4200 including shipping from Florida. I bought the car for $5000, and I've spent a little over $800 on a new water pump, heater core, ignition switch, light switch, and like-new drivers seat. With the engine swap the outlay will come in around ten grand, not a bad price for a clean 986 with relatively low miles on its engine.
I will be chronicling the swap in this thread. In the meantime have a look at my new engine.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-09-2024, 05:43 PM
#2
this engine looks great, congratulations!
PS: how old is the new water pump? If kind of new, I would swap it to the new engine, take pictures :-)
09-09-2024, 05:59 PM
#3
I put it on early last year, and I doubt I've driven the car more than a couple thousand miles since then — too busy working on it — so swapping the water pump might be the way to go. At the very least, I'll keep it as a spare. I can probably scavenge quite a few nice parts from the old engine.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-09-2024, 06:13 PM
#4
Holding that frothy dipstick, I decided right then and there to pay eBay a visit. The thought of dropping the engine and rebuilding it didn't enter my mind. For one thing, I don't have the special tools it would take. For another, it's an engine with 155,000 miles on it. I think I made the right decision.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-09-2024, 10:10 PM
#5
I totally agree, too expensive to rebuild these engines or transmissions and hope it goes well.
Hopefully, you’ll be back on the road soon. I think these cars are worth saving!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
09-10-2024, 05:05 AM
#6
Congrats on scoring a nice engine.
Before scrapping the old one, might be worth taking a few compression tests to pinpoint the problem. It might just be a problem with the oil cooler and the intermix was occurring there.
And now is the best time to easily get to those 'while you're in there' parts. Believe me, having gone the rebuild route, I know it can be expensive to start throwing more $$$ at unbudgeted parts but you'll never have a better chance to get to them like now. Things like radiator hoses, engine mounts, clutch, plugs, coils, fuel injectors, etc.
1989 928 S4 5 spd - black
09-10-2024, 07:05 AM
#7
Sorry to hear about your problem, but I like your attitude and decision to make lemonade out of the lemons. I will be watching for updates. Good luck with the swap.
It is a bit disturbing to hear that a 2000 2.7 engine gave up at 155,000 miles. I have about 149,000 miles on what is likely to be an identical engine.
09-10-2024, 09:12 AM
#8
I hear you. I talked to another 986 owner with just over 300,000 on it, so I was counting on getting more miles out of mine.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-10-2024, 09:43 AM
#9
If you are interested I have a engine swap check list originally based on the Pelican instructions. I have added a lot of details, some just for me some are more general.
Grant
09-10-2024, 03:11 PM
#10
You bet, Grant. Thank you very much. I also plan to read your engine-swap thread. YouTube has a number of videos I plan to watch as well.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-11-2024, 06:25 AM
#11
Grant
09-11-2024, 09:13 AM
#12
I greatly appreciate that, Grant. I noticed you built your own dolly. I'm shopping for furniture dollies on Amazon. I'm looking for one with a low profile, since clearance is an issue, and of course enough capacity. Speaking of which, do you happen to know the approximate weight of the engine?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-11-2024, 02:56 PM
#13
Motorist & Coffee Drinker
On these cars I've found that an engine support bar makes the job much easier. Here's a JFP post: Not a good idea to put a jack under the oil pan
Also, if you are careful with placement (NOT the middle of the sump plate) a heavy duty transmission jack works great for lowering and lifting in conjunction with the bar for stability.
One last note from me... The car needs to be raised up high to have clearance to move the engine past the suspension brackets. I don't have a lift and typically will have the car at several different heights through the process and only have it highest when moving it past the suspension. The first time I did it I used cheap jack stands on blocks - Stupid and unsafe. Splurge on some good jack stands if you don't have a lift available.
09-11-2024, 04:19 PM
#14
Fate must've wanted me to have an engine support bar. I bought this one at Amazon this afternoon after talking to a guy I call "The Grizzled Mechanic." Now you suggest the same thing. It's fate, I tell you.
https://www.amazon.com/VEVOR-Support-Capacity-Transverse-Garages/dp/B096FY98BS/
I've got some heavy-duty jack stands. Jack stands are the last thing I want to cheap out on. There seem to be a number of schemes to get the back end high enough to clear the suspension brackets. BTW, I don't see the necessity of removing the bumper cover, bumper, axles, drivelines, or even the transmission, as some have done. I prefer that those components remain where they are.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-12-2024, 06:13 AM
#15
... BTW, I don't see the necessity of removing the ... transmission, as some have done. I prefer that those components remain where they are.
I don't see how you can not remove the transmission. The transmission shaft goes into the clutch/flywheel so either the tranny has to be pulled back or the engine moved forward... which is impossible. If you move the transmission back you have effectively removed it. Not the same as a front engine car where you can remove the radiator and slide the engine off the transmission shaft. The rest of the stuff you can leave in place.
Grant
Reason: clarification
09-12-2024, 09:33 AM
#16
I defer to your greater experience in swapping 986 engines, Grant. I had assumed there would be room to slide the engine forward off the transmission shaft, like I've done with conventional engines. A boneheaded assumption (and not by any means my very first one).
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-13-2024, 07:40 PM
#17
Gotta admit, the thought of having a clean, low-miles engine in my 986 brings a grin to my face. It justifies the restoration I plan to do on the car. Someone commented in this thread that 986s are "worth saving." I second that. I think the series 1 986s will one day be regarded with the reverence we now accord the first series 911s, with a value to match. As much as possible, I want to ensure mine makes it to classic status. The numbers won't match, so it won't be "correct," but that might not matter to someone who can appreciate its exceptional beauty.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-21-2024, 06:57 PM
#18
If Kroil fails, consider a magnetic induction nut/bolt heater. I don't know what kind of dark magic this thing employs, but it works. Recently I pulled all the bolts out of a 1980s Fiero exhaust system. Soaking in penetrant did nothing. Less than a minute with this thing had them glowing orange and they all came out with the threads intact.
09-27-2024, 04:33 PM
#19
I also made my own puller and cam lock tools.
09-28-2024, 09:54 AM
#20
I know the Solution is expensive you can get them on sale at times for around 15-1600.00, But honestly with a nice low mileage engine the fact that it will never be a issue is great piece of mind, I know it's hard to spend that kind of money when your in deep enough as it is,.But even a" New " bearing can go bad, But with the Solution you will never need to worry about it no matter the mileage you drive, Good Luck,..!! Frank
