Old 09-12-2024, 07:13 AM   #15
elgyqc
elgyqc's Avatar
Originally Posted by LoneWolfGal View Post
... BTW, I don't see the necessity of removing the ... transmission, as some have done. I prefer that those components remain where they are.
I don't see how you can not remove the transmission. The transmission shaft goes into the clutch/flywheel so either the tranny has to be pulled back or the engine moved forward... which is impossible. If you move the transmission back you have effectively removed it. Not the same as a front engine car where you can remove the radiator and slide the engine off the transmission shaft. The rest of the stuff you can leave in place.
Grant
