Old 06-06-2023, 12:01 PM   #18
Will this retaining clip work with the OEM bearing? It looks quite wide/deep. The clip that came out of my car is basically a cylindrical wire that fits in the groove on the bearing. It is very thin and basically looks like thin steel wire (see pic below) and the groove in the bearing does not look deep enough to provide the needed clearance when installing the bearing.
Might be able to use thin wire and make my own but that sounds a bit of a pain and risky.
To those of you who used a new NSK bearing (elgyqc homeoboxter and others,) did you reuse your old circlip?
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
