Old 06-07-2023, 09:25 AM   #20
Homeoboxter
Originally Posted by nuvolari View Post
To those of you who used a new NSK bearing (elgyqc homeoboxter and others,) did you reuse your old circlip?
Yes, I reused the original cir-/wire clip, as mine wasn`t damaged. The bearing I used was different from the factory NSK bearing, I actually used two bearings and machined the groove on one of them at the same exact position as the original.
