Old 05-24-2023, 12:01 PM   #10
nuvolari
Originally Posted by elgyqc View Post
You may have already seen my IMSB thread here
My IMS bearing replacement thread.
As I remember it the bearing was a hard pull till the retaining spring got pushed out of the way (hence the arms of the puller flexing) then it came out smoothly.
Thanks so much for your link. I have seen and read all of your threads but the ole memory ain't what she used to be and thanks to your link, I now have a part to use as the sleeve/tube for the bearing puller. I'm assuming that's an exhaust tube available from your local auto parts shop? I've run out of tubes to try at Home Depot/Lowe's/Ace/Tractor Supply and I was getting worried.
So thanks for that and for the pic with the part number clearly seen.
Also, what are you using for the threaded part? Because that thread pitch is nearly impossible to find anywhere, local or online. I could only find one bolt locally with enough threads and it is 2.5 inches long. It is long enough to work but just barely. At least I think it is. I'll let you know when and if I ever get this bearing out.
I think my problem may be what I was thinking where I'm pulling against the sleeve instead of inside the sleeve. The IMS bearing tends to sit off center in the case opening so the clearance and tolerance for misalignment is small.
Anyway, off to spend another $10 on that exhaust pipe.
I can't thank you enough for that info!
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
