Old 04-11-2018, 06:44 AM   #11
1998 Boxster Silver/Red
Originally Posted by Brian in Tucson View Post
I would if I could, I looked it up in my Amazon orders and it's no longer available. Closest thing on Amazon is this:
https://www.amazon.com/Coolant-Reservoir-Porsche-Boxster-99610614708/dp/B078NG7CRQ/ref=sr_1_1?s=automotive&ie=UTF8&qid=1523400007&sr=1-1&keywords=Engine+Coolant+Recovery+Tank%2FReservoir+ For+Porsche+Boxster+99610614708
I wouldn't hesitate to get one, but install it so it's easier to remove, particularly the clamps on the hoses that connect to the car's coolant system metal tubes. I use worm drive clamps on those two hoses.
You can get a cable type hose clamp compressor on Ebay--works okay for $11, but I ended up resoldering the ferule on the cable. And a cheap set of coolant how picks from Harbor Freight, too. Replace those hoses, btw. My replacements were from auto parts shop bulk stock and went on tight enough that I had to use Sil-Glide to get them to slip on.
The quality of mine is as good as the factory oem.
That's arguable. If there's one thing I've learned from these forums is that, unless you're doing some modding, if it's connected to the engine, it's OEM only.
1998 Porsche Boxster
