Patience, patience, patience
+1 PITA. Make sure no youngsters are within hearing distance
It's all in those hoses, oil fill on the engine side of the firewall
I worked under and on top to get them undone and connected. I did not cut the old apart
I had it stuffed and it now hangs on my fireplace mantle
Have to use cable clamp tool. I was worried about breaking the oil fill tube but fortunately it did not. They aren't to expensive, so it could be good time to replace
Make sure to position the clamps so you know you can get the clamping tool on them in those tight quarters
Seal Grey
