Old 05-15-2017, 08:21 AM   #1
JBauer's Avatar
Changing oil
Going to try and change my oil. 1st one since I've owned it. Sticker in trunk says says Mobile 1. Any filter recommendations?
2003 with 40k. Canister filter, may change to a screw on in the future unsure.
Thanks in advance.
Old 05-15-2017, 09:10 AM   #2
Just use the factory Mann, HU719/5 x filter. Don't forget to buy crush washers for the oil fill plug.
Nothing special about Mobil 1. Use any Porsche A40 approved 5W-40 synthetic oil. I used Liqui Moly 2332 Leichtlauf last time (German oil for a German car.) The time before I used Motul 8100x-cess (popular on forums.)
Disaster is offline   Reply With Quote
Old 05-15-2017, 09:34 AM   #3
Ciao's Avatar
I've had great success with Mann filters and both Liqui Moly and Motul oil. Mobile 1 is great but overrated compared to those mentioned and others.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 05-15-2017, 09:54 AM   #4
The Mann or Hengst filters are fine along with any good brand of oil meeting the A40 requirements. Mobil 1 and Castrol are the easiest to find at your local auto parts and will work fine for a street driven car.
Here is a link to the Porsche A40 approved oils: https://rennlist.com/forums/996-forum/923972-new-2015-list-of-porsche-approved-a40-oils-and-a-strange-change.html
(Note: after downloading the file, change the file type to .docx to view properly).
Old 05-15-2017, 10:37 AM   #5
Buy a new canister and filter combination from the dealer, it costs about 25 or $30 which is not much more than what the cost of a filter is at the dealer. The reason you want a new canister is because if there is an oil pressure relief valve in the canister that tends to go bad after many many years. Cheap insurance.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 05-15-2017, 11:24 AM   #6
JBauer's Avatar
Thanks for all the great info. The previous owner told me the oil had just been changed but I want to make sure.
I'll probably get that kit online or next time I get near a dealer. Closest dealership is about 70 miles away 😐
Old 05-17-2017, 08:03 AM   #7
There Is No Substitute.
rick3000's Avatar
Use a Wix/Napa Gold 7211 cartridge filter.
Most cartridge filters are made entirely from paper, and the ends can sometimes delaminate/detach (rare) and let oil get through without being filtered. The Wix/Napa one have plastic end caps, which eliminates one more potential issue. They cost the same as other paper filters, about $10.
Old 05-17-2017, 08:24 AM   #8
The big issue is getting the fill quantity correct .Lots of Posts about overfilling -bad consequences.
The other very important issue is to inspect in the pleats for tell-tale debris
Old 05-17-2017, 09:03 AM   #9
I am No. 1348
algiorda's Avatar
One minor point, if you purchase one of those plastic Oil drain containers to catch the old oil, make sure you OPEN the vent valve so the oil drains as fast as it exits the vehicle. I ended up with a nice puddle under my car and made a 15min job a 30 minute cleanup effort! Doh!
I hate when I do stupid things like that.
algiorda is offline   Reply With Quote
Old 05-17-2017, 10:51 AM   #10
01101
And make sure when you drop the key for the drain plug, it doesn't fall exactly into the drain hole and block it. Then you try to reach your hand in and it burns because its really hot, but its too late anyway and there is oil all over the floor.
alm001 is offline   Reply With Quote
Old 05-17-2017, 02:09 PM   #11
That's EXACTLY what I did on my first Boxster oil change, about 10 years ago. Or the drain plug itself, I should say. You just don't realize how much 9 qt of oil is until you see it as a dirty black lake on your driveway. Within minutes after finishing the oil change and massive oil spill cleanup process I had my cordless drill in hand, with the biggest bit I had (1/2"), and proceeded to create multiple holes in the collection surface of the used oil container. It doesn't matter where I drop the drain plug anymore
Old 05-17-2017, 02:17 PM   #12
Keep in mind also that when it first starts to flow it REALLY splashes. Starting a good while back, I started doing this: I cut a plastic, 1-gal milk jug down, removing the top (handle) and bottom portions, so I basically have a maybe 6" square "cylinder" that I set onto the collection container surface. I'm not 100% accurate every time, but I aim the stream towards the middle of that...it helps a lot with that splashing.
Old 05-17-2017, 02:53 PM   #13
JayG's Avatar
Or get one of these
the entire area under the cover is a screened opening
no splashing
https://www.amazon.com/Hopkins-FloTool-11837-Quart-Drain/dp/B00004X13X
I put it in a low plastic container just in case of a spill
Sterilite - 1655: 28 Quart Storage Box
Old 05-17-2017, 03:09 PM   #14
njbray's Avatar
I like to use large Puppy Training Pads layed out around my oil container. The soak up any drips or spills. I also drop the filter onto a pad - they can soak up a lot!
Also check oil filter.
Old 05-17-2017, 04:52 PM   #15
That's a great idea! I've used newspaper...but invariably (as soon as I start!) the wind kicks up and they're all over the front yard. NOT absorbing used oil..
Old 05-19-2017, 01:55 PM   #16
changing oil before winter storage
I have been convinced that changing oil before winter storage is best.
What about changing oil again in the spring with no startups or miles on the oil..
Does it oxidize just setting in the crankcase?
Is this a bad thing??
PatM is offline   Reply With Quote
Old 05-19-2017, 02:15 PM   #17
Changing it again in the spring does not hurt anything, but is also not necessary. Oil breaks down from contamination during the engine running, so changing it before putting the car up for the winter does not significantly alter the oil, but putting the car away with used oil leaves sensitive components exposed to acid and other combustion by products which can deteriorate them. Change the oil, put the car away, and do not start it, and you will be fine come spring.
