Thread: Changing oil
Old 05-19-2017, 02:15 PM   #17
JFP in PA
Originally Posted by PatM View Post
I have been convinced that changing oil before winter storage is best.
What about changing oil again in the spring with no startups or miles on the oil..
Does it oxidize just setting in the crankcase?
Is this a bad thing??
Changing it again in the spring does not hurt anything, but is also not necessary. Oil breaks down from contamination during the engine running, so changing it before putting the car up for the winter does not significantly alter the oil, but putting the car away with used oil leaves sensitive components exposed to acid and other combustion by products which can deteriorate them. Change the oil, put the car away, and do not start it, and you will be fine come spring.
