Thread: Changing oil
Old 05-17-2017, 02:09 PM   #11
Frodo
Originally Posted by alm001 View Post
And make sure when you drop the key for the drain plug, it doesn't fall exactly into the drain hole and block it. Then you try to reach your hand in and it burns because its really hot, but its too late anyway and there is oil all over the floor.
That's EXACTLY what I did on my first Boxster oil change, about 10 years ago. Or the drain plug itself, I should say. You just don't realize how much 9 qt of oil is until you see it as a dirty black lake on your driveway. Within minutes after finishing the oil change and massive oil spill cleanup process I had my cordless drill in hand, with the biggest bit I had (1/2"), and proceeded to create multiple holes in the collection surface of the used oil container. It doesn't matter where I drop the drain plug anymore
