10-04-2012, 06:23 PM
Transmission Rebuild?
Okay here we go!!
To make a long story short, my previous owner failed to inform me that my 2nd gear synchro is failing. Here we are 6 months later, just becoming more and more frustrated that I look like that guy that can't drive his sports car... It MUST be the transmission
Haha well here we go.
Its a 2002 Boxster S... I work at a German Auto Shop so I can get parts for it without fail. After contemplating rebuilding it myself I decided I should start by pricing out parts. With all parts including all seals, bearings, 1st-6th & Reverse syncrhos, and 2nd gear. It came to a grand total of just over $2,500...
Calling around to "local" porsche wrecking yards (in SF area), Parts Heaven as an example, they all seem to sell used transmissions for $3500-$4500. Of course with a limited warranty.
Calling the dealer they want $8000 for a factory rebuild (Which i get 20% off for wholesale); Which is definitely NOT and option lol
So here we come to my questions!
1. Are there special tools required, like there is in 911 transmission rebuilds?
2. Could I get away with just replacing 2nd gear and it's synchros, plus of course all seals? (Of course I would also visually inspect everything and replace the obviously worn parts.)
3. Are there any guides that I just can't seem to find? It seems pelican parts doesn't have one, my Bentley book doesn't have one, and even searching forums I cant seem to find one. Any help?
4. Has anyone done this before? Tips/ tricks?
All help is greatly appriciated
Thanks guys!
~Brad
10-04-2012, 06:36 PM
10-04-2012, 06:42 PM
Moderator
How about $400? No, seriously...
986 five-speed tranny - unmodified Audi 012?
There. Saved you at least a thousand.
I was once looking around a junk yard after I had done a clutch job. I was among the transmission section helping a friend look for a transmission for a Mitsubishi Eclipse and noticed how similar a transmission on the shelf looked like to mine. As a matter of fact, it was the same, and it was labelled under the Volkswagen shelf.
If you actually take a look at your transmission on the Porsche you will see the volkswagen/audi logos on there!
10-04-2012, 06:58 PM
Woah, woah, woah. You're joking me. Is this for real? However; I need a 6-speed, not a 5-speed
They talk about 2nd/3rd gear being geared differently. Any idea on the difference? lol
10-04-2012, 07:16 PM
Moderator
I'm serious as a heart attack. However I don't know much about the 6- speeds. The only difference the gearing ration would be 1-2mpg more on highway speeds due to lower rpms at higher speeds.
Lower gearing = more rpm at higher speeds. Higher gearing = lower rpm at higher speeds. Lower gearing is more optimal in racing applications as the torque curve is optimal at higher rpms of 4-5k rpms. Higher gearing is more optimal in econoboxes, as lower rpms= less power but more efficiency. That is why my honda fit is 2,000 rpm going 70mph and that is why the boxster is 2,700 rpm at 70mph, both being in 5th gear respectively.
10-04-2012, 07:27 PM
1999 base
10-04-2012, 07:57 PM
Engine Surgeon
I have a good used 6 sped Boxstser S tranny for 2,500.00
Its currently in our test car that we'ves used to develop the IMS Solution and now that we are done with that development we don't need to tranny or the rest of the car, so its time to part it out. 48K miles, no issues at all.
US Patent 8,992,089 &
US Patent 9,416,697
10-04-2012, 09:19 PM
Why rebuild? A bad synchro is no big deal, just learn to drive with it. The tranny will last 100k miles or more with a bad synchro.
If it grinds on a downshift, just learn to double clutch. I can do a money shift on a tranny with a dead synchro if I want to, not that I would. Any one who has had an Italian car can vouch for this.
If it grinds on an upshift, try this. When you go shift from 1 to 2, right before you shift, with your foot off the clutch, pull down gently on the shifter towards 2, not too much pressure, keeping the light pressure on the shiftert, push the clutch in and it should go right in.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
10-04-2012, 11:51 PM
I went through your exact scenario 2 1/2 years back, it was a 2002 S also. Looked into rebuilding it locally without luck, ended up sending it out to G-Box for rebuild / 2nd gear syncro. It ran a touch under $3k with shipping both ways, they did a great job. I also addressed the IMS while in there, put in a new clutch too.
10-05-2012, 03:30 AM
Ex Esso kid
Originally Posted by Meir
Thanks! Now I know what the beautiful 50+ year old puller with two sets of extension arms I have from my dad was used for. As you would expect, my old unit makes the one in these photos look like junk.
PS I disagree with San Rensho, not addressing the synchros is like allowing a cavity to progress into a root canal.
10-05-2012, 05:25 AM
Wow, so much for getting a S... I'll go a-wall if I get IMS AND a tranny rebuild.
10-05-2012, 08:24 AM
If the gears aren't grinding, I would thing a bad synchro in and of itself is not going to cause any problems.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
10-05-2012, 11:21 AM
If the gears weren't grinding there would be no problem at all, I agree. But they are. And when it's cold its nearly impossible to get it into gear. I have no idea how long the previous owner may have drove around like this, and second gear is probably starting to round off..
I must say, Jake you're a life saver, I'll be in contact with you shortly. Thanks a ton
10-05-2012, 12:23 PM
Borrowing this topic a bit, is it actually possible just buying a Audi 012 gearbox and install and there will be no difference in the feel?
I have problems with grinding sometimes and found a Audi 012 with 25000km on it for like, 300 usd, will do my clutch and ims next spring and if this is the case, i will drop a new gearbox in there also.
Have a 5 speed manual, 2.5l engine from 1998
10-05-2012, 12:54 PM
Originally Posted by Mrmaddbrad
Okay here we go!!
If rebuilding the trans as a DIY project is within the scope of your capabilities, I think you are going overboard with your parts list.
All you should need is the 2nd gear synchro and a seal kit. If you are worried about damage caused by a long period of shifting while grinding, you can replace the 2nd gear dog teeth and possibly the 1st/2nd gear slider. That should be it. Why would you even touch or replace any other parts?
Of course, once you get in there, you may find that the trans is worn out extensively, at which point you should consider buying a used trans. One of my track buddies broke his 5 speed trans on his 99 Boxster. He was able to find a used trans for $700. Be patient and a good deal on a 6 speed trans will come along. A lot of Boxsters get parted out due to dead engines.
10-05-2012, 08:03 PM
I found a 5spd for $750 and a serviceable stock Dual Mass flywheel for $150 at OK Foreign last year. Even with shipping it was far less than SoCal dismantlers. Go fishing and see what you catch.
10-06-2012, 08:04 AM
5-spd replacements are readily available for well under $1,000. The 6-spds seem to be harder to find and quite a bit pricier (~$2,500). You may have to be patient to find a good deal on a 6-spd.
10-08-2012, 09:27 PM
As much as I want to be patient, it's hard to be, as i feel like this is going to be needed sooner than later.
Seventythree, you seem to have the same view on this as i do, however all the other guys at the shop i work for seemed to suggest replacing everything else at once "since you're in there"... Meh, seems like a waste of money to me.
But this still doesn't answer my biggest concern; Are there special tools to open/unbuilding the trans?
10-09-2012, 10:59 AM
G Box fixed my 2nd gear grind as well 2.5 years ago now all I have to do is warm the car for 90 seconds or so and shifts pretty smooth into second all other gears were and are fine. From what I've read here the 6-speeds grinding into second is a common problem that G Box has figured a fix which Porsche itself has not. Lots of posts on here about G Box. Good luck.
10-14-2012, 12:23 PM
Still need a trans  . Does anyone have a good source?
