Old 10-05-2012, 11:21 AM   #13
Mrmaddbrad
If the gears aren't grinding, I would thing a bad synchro in and of itself is not going to cause any problems.
If the gears weren't grinding there would be no problem at all, I agree. But they are. And when it's cold its nearly impossible to get it into gear. I have no idea how long the previous owner may have drove around like this, and second gear is probably starting to round off..
I must say, Jake you're a life saver, I'll be in contact with you shortly. Thanks a ton
Mrmaddbrad is offline   Reply With Quote
