07-04-2011, 04:02 PM
#21
Originally Posted by insite
Extra engine.
Nice to have a spare, eh?
Btw frodo, this doesnt change the direction you want to flush the motor at the pump
OK, I was half way through typing that question when I realized you had already anticipated it and responded (with the answer I expected!)
The other question I had was one of PRESSURE. I've been told (thank you, JFP) that too high a pressure, including that produced by a garden hose, could be a problem when flushing, especially with the radiator, heater core and oil cooler. Per suggestions from more than one source, I plan to back flush the engine and the rest of the system separately. With regard to the engine flush, the first two (radiator, heater core) wouldn't be involved I guess (though I'm wondering if I'd need to clamp off the other big hose---the one not shown in my pics, the one NOT going through the t'stat---to be sure that's the case.) That may be all moot, though, since back flushing the engine (ie through D) will still include the oil cooler.
The conclusion would then have to be that, if too high a pressure can be a problem, that would still be true regardless of whether you're doing the engine circuit or the rest of the system (radiators, etc). True?
For those who have done back flushes, have you worried about (or even known about) any potential problems with too much pressure? If so, how have you worked it so as to not exceed a "safe" pressure? If you didn't worry about it, have you had any problems?
I ask, because I had considered ( considered!) using this:
It's a plumbing tool, for unplugging stuck drains. The attractive feature is that, when attached to a hose and water turned on, the black rubber part expands, filling whatever hole it's in. It creates a pretty tight seal. Then the water that flows actually pulses somewhat (maybe helping to stir up missing impeller blade pieces!). Without being able to measure the pressure it creates, I'm a little hesitant to use it. OTOH, unless I can incorporate some sort of pressure gauge into the system, I'm not really sure how to monitor the pressure anyway (with or without the plumber's tool).
Thoughts?
07-04-2011, 05:00 PM
#22
Porsche "Purist"
Here's some pictures of the original pump in a 2000 2.7 with 40K miles. Looks pretty good, but I'm replacing as many problem parts as possible.
This indicates that the pump is original since the gasket had to be cut:
All blades intact and no slop in the bushing:
1987 924S. 2002 996TT. PST-2
07-04-2011, 08:52 PM
#23
Track rat
Ok I gave this some thought and I think I understand why the motor is on the pressure side of the pump. It creates a higher pressure zone when picking up heat in the water passages which raises the boiling point. A few psi makes a pretty big difference (Boyle's law). Now the T-stat simply acts like an automated valve. When it opens coolant is sent to the radiators and when closed coolant returns to the water pump for recirculation through the motor.
Frodo,
I like the water jet idea a lot. The pulsing action should help to free anything that got lodged internally. As to pressure, you can get a drip system pressure regulator that will bring your hose pressure down to 15-30psi at any garden center or hardware store. Also use a ball valve so you can control the water flow and ramp it up slowly. I might put a catch screen at the other end and take inventory of everything that comes out. You can count the pieces and see if you got everything.
07-04-2011, 09:25 PM
#24
Is the water pump able to be swapped without lowering the engine at all?
Is it a one-man job? I always get pretty paranoid when attempting a job that requires the car to be on jack stands.
07-04-2011, 09:40 PM
#25
Porscheectomy
I did mine yesterday with the rear wheels on ramps, no engine lowering. But the back of the car does need to be up in the air.
I didn't need to remove the thermostat hose either. The pump can come out through the bulkhead access door. I also didn't replace all my coolant, it was only a couple of years old so I just replaced the 2 gallons that drained from the pump.
There are alot of jobs that require the car to be on jack stands. Limiting yourself to jobs with the wheels on keeps you from doing alot of fairly easy jobs.
07-04-2011, 10:07 PM
#26
I know... working on acquiring a lift, but the shipping/hauling home aspect is quite a hurdle.
I had an "experience" once when lowering my Blazer way back when... car on jack stands, lowering rear axle, and *SNAP* whole thing lowered on me... scary.
I'm also nervous because the jack stand area is like a donut, but the top of the jackstands is a "claw"... (they need some kind of standard here). where do y'all put the floor jack so as not to take up the jack stand spot?
EDIT: I have had the rear on ramps before and have had been able to "one tire at a time" a few jobs (spark plugs, brake rotors/pads), but thinking of tackling the motor mount / water pump combo as preventative maintenance.
07-05-2011, 02:49 AM
#27
Still seems weird to me. As Insite points out, why would you want a system where, when the water (coolant) circulating around the engine gets hot enough to need the radiator action for removing some heat, you then start pulling relatively cool water from the radiator part of the system across the t'stat, presumably causing it to close back down? Sorta defies logic.
Frodo,
Not familiar with your 'drip system pressure regulator' but sounds like it might be worth looking into. As to the valve, you don't think that could be controlled well enough with an assistant slowly opening the spigot the hose is attached to? I'm no engineer---probably already abundantly clear---so I don't really know much about characteristics of the various different kinds of valves.
I had already planned on doing the catch screen thing.
Originally Posted by stateofidleness.
I agree with blue, it is doable as a job on its own. Since I was doing the motor mounts at the same time, I think I did raise/lower the engine some when trying to get to the bolts holding the water pump in place. Made it a little easier, but I'm pretty sure I could have done it without doing that. I also worked from inside the car through the access panel behind the seats to get the top bolts. How old is your motor mount? As Pedro (and others) have pointed out, these jobs kind of go hand-in-hand. Doing one kinda makes the other easier.
Geez, I know what you mean. I was helping my kid replace a fuel pump in a 1999 Mercury Marquis (his gf's car---I call it 'the starship'), and we had to remove the fuel tank (since that's where the fuel pump lives). I was nervous as hell gettin' underneath this beast of a car sitting on jack stands. I've got lots of lumber layin' around that I'll stack up under strategic support points in case something gives way. If you're removing a wheel, you can also slide that underneath the car. The trick is to make it safe without getting so much stuff under there that you have limited access to get you under there.
As far as the 'one man job' question: I've done everything (so far) by myself.
Do a Search on "jack stands"---there's all kinds of recommendations and good advice out there. This is how I do mine...
Jacking the Boxster
...but there's lots of other techniques that can be used. With my system, BTW, note that I don't get under the car with just the jack/4x4 holding it up. One, because there's a small chance the hunk of 4x4 could suddenly crack and, two, I just don't trust a jack that much. I think others would agree with that.
07-05-2011, 04:43 AM
#28
topless -
you're definitely correct that the pumps are designed to apply pressure into the engine; this is normal. it's still possible (and usual) to do this, but to put the thermostat on the other side of the engine at the large outlet. this way, pressure is into the engine, but the thermostat is placed in hot flow rather than cool flow. bottom line: the thermostat is usually (i thought ALWAYS) at the coolant EXIT of the engine, not the entrance.
07-05-2011, 04:45 AM
#29
frodo -
don't worry about pressure unless you have an actual means of pressurizing your system. the pressure in your engine can't get above the water pressure from your hose, which is not very high.
you asked what COULD happen if the pressure got too high. the answer is that you would pop a freeze plug out of the water jacket. these are pressure relief plugs designed to pop out if the coolant/water freezes & starts to expand.
07-05-2011, 10:58 AM
#30
What is the nature of the rear motor mounts? Can and damage occur by lowering the engine at the front? How much rotation is allowable so as not to damage the read mounts if any at all. Its hard to see in there without a hoist
986 00S
07-05-2011, 12:32 PM
#31
Don't really know for sure, but judging by the lack of any mention of such a problem in the 2 or 3 DIYs I've read on this, apparently not. I never raised or lowered the engine more than 2-3" either way...wouldn't think that would be a problem.
07-08-2011, 05:19 AM
#32
Well, finally got an opportunity to do some flushing. Don't know if this was the ideal set-up, but this is how I did it:
This was to flush the engine half of the system. When I first flushed, I left the pressure gauge off, and just let some water come out of that opening. After a minute or two, turned off the water and put the pressure gauge where you see it here. (It was just this little cheapo made in China thing---all I could find locally. Got some rubber stoppers, drilled a hole through one and screwed the gauge into it.)
To flush the radiator part of the circuit, I put the hose (with the plumber attachment) into the big hose that normally would attach where the t'stat is.
Ran MANY gallons of water through both circuits and you know what? I got squat. I sieved every ounce of water and saw, essentially, nothing. (Did see two tiny pieces of something---much smaller than the head of a match---that might have been miniscule pieces of impeller blade. It was hard to tell, they were so small.) Funny thing is, I never got the pressure gauge to register anything above zero---pointer seemed pegged there, never moving once.
Don't really remember much fluid dynamics, but I wondered if, with the water moving past the gauge with a certain amount of speed, it created a relative low-pressure area. Like air moving over the top of a wing, or like when someone's smoking in a car and opens the window---the smoke rushes out towards the low pressure zone (ie outside). Dunno. I crudely tested the gauge at one point: held the hose directly against the opening in the stopper and turned it on. Lots of leakage, but I could get the gauge up to about 30-35 psi doing this.
So I don't know. Maybe I wimped out on how much water pressure I was putting through? Seemed like it was a fair amount, but with the gauge telling me NOTHING, I wasn't sure how far I should push it.
Emailed a guy that I've worked with before, works at this big shop that specializes in pcars. I've seen EVERYTHING imaginable there, Porsche-wise, including many track vehicles...they always have at least 6-8 Porsches at any given time. Anyway, he emailed back about their experiences with water pumps. Some excerpts:
We have done probobly 25-30 water pumps on Boxsters and a few 996's. I have yet to see one come out with the impellers intact, the bearings fail and the the impeller hits the block and breaks
The very first one we did (had to be 6 years ago) the impeller was gone, all of it!. We pulled the radiators, all the hoses, back flushed the system. Never found any of it! Put it all back together and sent it down the road, he still has the car with no problems.
We dont even bother flushing them now, it is never an issue.
I would...say you have nothing to worry about.
I've had several other knowledgeable sources give me the same advice.
So, while it's clear that some people have seen problems with this (JR), it seems to be relatively rare. In a perfect world I'd have a 3 car garage with a lift, two reliable back-up vehicles (instead of one---a '96 Camry with 195k miles), and lots of time on my hands. As it is, I really don't see me tearin' into this, looking in every nook and cranny trying to find 1/4 gram of plastic. Sooooo, unless I come up with any other ideas, I'm puttin' it back together and goin' with it. Mine will be the test case car, eh? Life...it's a crap shoot, right? You get lucky or you don't. Time will tell....
07-08-2011, 06:16 AM
#33
Engine Surgeon
If you have missing impeller blades and they were not found during the flush, then you still have missing impeller blades- they do not disappear.
When the blades become lodged into capillaries within the head is when we see issues and it takes more than water pressure to remove them as heat and engine vibration helped to get them there.
This is why changing the pump electively before any failure is experienced is so beneficial. That means changing the pump every 3 years, no matter the mileage.
If you have missing impeller blades the only way to remove them may be while the head is on our milling machine having a crack repaired.. Digging these out during crack repairs is common practice, its what taught us the true reason for most unexplained head cracks from engines that never had overheated.
US Patent 8,992,089 &
US Patent 9,416,697
07-08-2011, 06:39 AM
#34
Thanks, Jake. I knew that.
| Thread Tools |
| Display Modes |
Linear Mode
