Originally Posted by stateofidleness
Is the water pump able to be swapped without lowering the engine at all?
I did mine yesterday with the rear wheels on ramps, no engine lowering. But the back of the car does need to be up in the air.
I didn't need to remove the thermostat hose either. The pump can come out through the bulkhead access door. I also didn't replace all my coolant, it was only a couple of years old so I just replaced the 2 gallons that drained from the pump.
Is it a one-man job? I always get pretty paranoid when attempting a job that requires the car to be on jack stands.
There are alot of jobs that require the car to be on jack stands. Limiting yourself to jobs with the wheels on keeps you from doing alot of fairly easy jobs.
