Old 04-13-2019, 08:29 PM   #1
Window tint
Anyone have any secrets to putting tint on a 986? I did today and am taking off tomorrow to try again. The angle where the mirror attaches really gave me a hard time. Also, so bubbles appeared later that weren't there earlier. I think I really need to make a template out of cardboard for that angle and start there.
Tips, advice?
Old 04-13-2019, 09:05 PM   #2
Need For Speed
KRAM36's Avatar
Go on youtube and watch some videos on how to tint the windows. I just bought some 90% IR 38% VLT Premium UV Blocking Shatterproof Nano Ceramic Window Tint and a window tinting installation tool kit.
I think after watching the videos I'm ready to go on this endeavor.
2003 Boxster S
Old 04-13-2019, 10:23 PM   #3
It's easiest to take the glass out and do it. It only takes a few minutes to get it out.
Once out, you can use tons of water. Lay the glass flat and douse it and the back of the film with water (I actually used a running hose...even better if you have a tub filled with water and the glass submerged). Once the film is positioned, use your squeegee to force the water out. Let it set for 5 minutes, then use a scribe blade to trim around the edge, leaving a 3-5mm reveal (the reveal will keep the film from peeling at the edge from rubbing the weather stripping).
Doing it with lots of water allows you to position it better and prevents air bubbles and trapped debris.
Old 04-14-2019, 08:00 AM   #4
1998 Boxster Silver/Red
Remove windows? Plenty of water?
My tint guy does the side windows for $25 each. Done.
1998 Porsche Boxster
Old 04-14-2019, 10:02 AM   #5
Let a pro do it, most warranty their work for at least 2 years. It only cost me $100.
mgfranz is offline   Reply With Quote
Old 04-14-2019, 10:30 AM   #6
Do you guys pay someone to change your tampons, too?
Old 04-14-2019, 11:56 AM   #7
Need For Speed
KRAM36's Avatar
Lol pw. I might save $25 doing the tint myself, but that's not the reason I'm doing it. It's for fun, plus learning the skill and if it turns out good, it will give me satisfaction in a job well done by me, not by someone else.
2003 Boxster S
Old 04-14-2019, 12:01 PM   #8
98 Arctic silver 986
tommy583's Avatar
do you guys pay someone to change your tampons, too?
lmfao......................
Old 04-14-2019, 12:18 PM   #9
So, you're telling us you change your own? Not me. I'm not getting my hands dirty.
I'm sticking with pads for now.
Old 04-14-2019, 01:01 PM   #10
Who's askin'?
maytag's Avatar
Y'all are FUNNY on sundays! Hahaha
Old 04-14-2019, 04:56 PM   #11
Will there be cake?
tonythetiger's Avatar
Tips, advice?
of course its fun to do stuff yourself. I have applied tint in the past, but found that the secret is use a tint guy. Also use the best film you can out there; some really good choices and a tint shop with high ratings will steer you right. I use 3M™ Automotive Window Film Crystalline Series. It isn't dark, yet rejects the heat and UVs...its amazing and my installer guarantees it for life, even if I scratch it.
While having the window out would make it easier, taking the window out isn't trivial either... you have to work around the airbag, make sure you don't disconnect it with the battery connected (you need to visit the dealer for resets after that) It takes 20 to 40 minutes a door in removal, another 20 - 40 minutes to replace.
Old 04-14-2019, 07:04 PM   #12
Need For Speed
KRAM36's Avatar
Doesn't look that hard to do as long as you have the right tools. Check out this video, no door frame around the window, like our cars.
I'll probably put mine on at the beginning of May.
2003 Boxster S
Old 04-15-2019, 09:51 AM   #13
LOL - we need a 'hall of fame' or 'best of...' sticky thread around here
"Cool Prius!"
- Nobody
