03-14-2017, 09:38 AM
#21
07 Carrera S Cab
Originally Posted by mikefocke
On another forum Marc reports 172k on his first with 130K+ on his second pump.
I like MarcW's water pump change schedule! I think he's still on his original clutch at 300K miles too. Oh, and my 2nd water pump is still holding up after 8 years (original one lasted 8 years), so I hope the AGE theory doesn't hold water.
03-14-2017, 09:39 AM
#22
Originally Posted by JFP in PA
Can't agree to eithier point.
We have run 160F stats on fully insrumented cars and consistenly found both lower coolant and more importantly oil temperatures when operating at steady state (cruise speeds). Coolant temps typically drop from around 205-210 to the mid to high 170F range. Oil temps drop 20-25F. Used oil analysis on cars befor and after adding the low temp stat showed the oil was in better condition after equivlant usage.
We have had multiple cars in the shop that had metal impeller pump failures that resulted in significant damage to the engine cases behind the pump. Several of these cars showed coolant circulation issues after being fitted because the new pump lost efficency due to the increased gap behind the impeller. Trimming impeller blades is a method to slow pump circulation rates, which is an old racers trick to improve high engine RPM cooling as usually the pump is moving coolant too much coolant under those conditions. But like everything else, there is a "too much" limit in doing this, when the reduced flow leads to over heating, particularly at lower engine RPM levels.
There are reasons the factory used compostie impeller pumps on these engines, and why they equip all of their high performance engines (turbos, etc.) with 160F stats from the factory.
That and what this other guy said that I was about to quote:
(From 2012)
In actual fact, it works the other way around: As noted above, the combination of engine vacuum in the sump and 170-180F coolant temps has demonstrated (by multiple used oil analyses) that there is no fuel or water contamination increase when running the lower temp stat; and the lower oil temps afforded by the lower coolant temps lengthened the oils ability to stay in grade, not shortened it.
Actually, there is substantial empirical (ranging from improved UoA’s, to even a pre and post install Dyno pull or two) to anecdotal (“improved fuel mileage”, “faster warm up in cold weather”) data available on this subject (ad nauseum), but that would require actually doing a search to understand why changing the thermostat is a positive, and in which models Porsche already uses them from the factory.
So, yes, these things actually work……………………..
03-14-2017, 10:13 AM
#23
There are a few on this forum that consistently know WTF they are talking about and JFP is one of them
03-14-2017, 10:33 AM
#24
JP, you are just throwing information that is not possible to measure easily and if you did, should have graphs and data showing it.
About the thermostat. You are measuring the temperature after the thermostat, not at the radiator. All 986s(without center rad) has the same thermal capacity. The only difference is that the proportion of the heat is located in the engine or in the radiator given the same amount of usage and type of usage. The delta temperature(difference between two values) will be different I agree, but it will not affect daily function or be worth it. All you will get is a car that is terrible to use in the morning when its 40-60F outside with much less cabin heat and increase emissions. Considering even california weather that is still half the time used as a commuter.
About the impeller damage. I would love to see pictures. Also considering the person who let a weeping pump long enough for the water pump to fail axially, they wouldn't see the difference in coolant performance anyway. Proper usage you wouldn't see major failures of the pump.
I am just trying show that people should look at a choice in the big scheme of things rather then facing specific problems. Lower Thermostat, under driven pulley, oil cooler, 3000 miles oil change on synthetic , great way to make money on people with more money then time to educate themselves on their car. Listening to "experts".
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
03-14-2017, 12:28 PM
#25
Again, I disagree. And I apologize that the shop does not take the time to prepare pretty Power Point presentations for you, but that is not what we are about.
The thermostat functions as a throttling device, restricting the volume of coolant returning from the radiators to the engine. As such, a lower temperature stat actually opens sooner (read at a lower temp) than the factory stat, so operating a vehicle with a 160F stat will actually get heat sooner than with an OEM stat. This is a common observation customers give us after changing over, and as we live in an area that often sees weeks of zero or sub zero temperatures, customers that use their cars as daily drivers would be screaming if there was a heat or warmup time issue. Yet in all the years we have been installing these stats, we have not had one complaint, only comments that is nice to get more heat sooner in the winter because the stat is opening sooner and allowing more warm water to circulate.
Metal impeller pumps do not have to completely fail in order to chew up the engine cases. There is only a few thousandth's of clearance between the impeller and the cases, and when these pumps start to wear and the impeller shaft starts to wobble, and they all do, the machining starts. We have had cars come in with complaints of seeping pumps, only to dump the coolant and find it full of finely ground aluminum, requiring us to flush the system to get all the metal out. And after installing a new pump and fresh coolant, the cars returned with complaints of running hotter than normal, particularly in warmer weather. A couple of these customers got annoyed enough about this issue to take the cars back to a dealer, who pulled the water pump, looked at the damage, and promptly told the owners that they needed a replacement engine as the impeller damage could not be repaired. They also confirmed that this is something they see regularly with metal impeller pumps, and why Porsche does not use them.
As for whether or not people choose believe, or even listen to what I have to say, that is entirely up to them. And quite plainly, I do not care if they do or do not choose to listen to us. Those that know me will tell you that I have never posted the name or location of my business online, or on any of the forums I either moderate on or participate in. We don't need any more business than we already have, we are doing just fine. We simply try to inform interested parties in what we have observed or experienced over some thirty years of building, racing, and repairing Porsches.
03-14-2017, 12:49 PM
#26
I though mine failed at about 125K...I had a very slight coolant loss. During replacement, I realized that one of the mounting bolts (lower passenger side) was very loose. I went ahead with the replacement (along with thermostat) but my original pump looked fine as far as no play and no impeller wear.
Oh well.
03-14-2017, 12:56 PM
#27
Again, I disagree. And I apologize that the shop does not take the time to prepare pretty Power Point presentations, but that is not what we are about.
As for whether or not people choose believe, or even listen to what I have to say, that is entirely up to them. Those that know me will tell you that I have never posted the name or location of my business online, or on any of the forums I either moderate on or participate in. We don't need any more business than we already have. We simply try to inform interested parties in what we have observed or experienced over some thirty years of building, racing, and repairing Porsches.
+986, 996, 987, 997, 981, 991, 911, etc
You don't want to take his advise, don't.
No skin off his nose or anyone else
03-14-2017, 01:01 PM
#28
Before low temp thermo, hwy cruising was right around 194 degrees, summer time.
With low temp, my summer temps run around 176 degrees. In the winter it runs 172 degrees. This is using the Torque app for water temp.
Now in stop and go the temp will move up in the 212-215 and the fans come on same as reg thermo. But cruising 50+ mph the temp definitely runs cooler.
Cooler is better
Seal Grey
03-14-2017, 01:35 PM
#29
I appreciate that you help the community. I won't argue that its the only reason why I keep participating. My field of work require thorough study of every situation and we can't forget the big picture. I am just trying to say that the solution isn't always clear cut. You might solve 1 issue and cause two problems. Just like IMS issues is to Porsche cutting cost on engine head castings .
As a friendly reminder, re-read yourself on the heater core part. Heaters(cabin radiator) and engine are on a closed loop system. No thermostat in between. In the morning, you will feel heat at around 100F on the cluster.
Cooler is better
The result is the same(negligible error considering its two different test moments)... 176Fis 6Fto 170F and 194F is 8F to 186F. that 6-8F is the limitation of flow.
At max heat capacity(radiator at 212F), both thermostats should be open at 100%. ANY difference in flow here would mean one is actually better then the other. Under that situation you could say one thermostat is better then the other. Any other test in meaning less for a daily driver. Tracked Cars are a different story where you can tune the fuel and timing map to take advantage to the lower intake temperatures.
03-14-2017, 01:45 PM
#30
The heater uses a small bypass from the engine, but when the thermostat opens, more warm water is in motion within the cooling system and the engine, heat comes up in greater amounts within the cabin; so the thermostat does affect how much and how soon you sense heat coming from the car.
And, regardless of what you do for a living, it is never a good idea to look down your nose at anyone.......................
03-14-2017, 02:15 PM
#31
2003 S, Arctic Silver, M6
Just an observation.
I've learned a ton from JFP and he has never steered me wrong. His experience with multiple Porsches over a long period of time has allowed him to see many, many more failure modes than any one of us will observe. The large sample size of cars he has been exposed too with & without low temp stats and with & without metal impeller pumps tells me his practical experience in this area carries more weight than the theoretical viewpoints.
One very real world piece of knowledge that JFP shared was to always use Porsche Brand MT fluid in the 6 speed. My thoughts were 'hell, gear oil is gear oil. It's all the same". Well I ignored JFP's advise, went with XXXXX brand and the shifting could only be described as s#itty. I drained it, put in the 'unicorn tears' oil from Porsche and it is 100% superb.
Like Jake Raby, JFP has seen it all. We would all do well to heed his advise when it is freely given.
03-14-2017, 08:33 PM
#32
Totally Agree with this
I too have learned a great deal from JFP, couldnt agree more
03-18-2017, 09:35 AM
#33
Metal vs Composite impeller...
Posted a few days ago about installing a pump w/ a metal impeller. Live and learn, I guess.. Do more investigating before purchasing parts for these cars, especially something engine related.. Asking questions is never a bad idea.. Plenty of people way smarted than me out there.
Anyway, pulled the "brand new metal impeller pump" and installed a Pierburg w/ a composite impeller. Works great.. Getting to be an expert on pulling and installing these pumps.. Thanks again for the insight, feel better about things.. Pumps are cheap compared to engines..
As I post earlier I also installed a 71C (160F) stat when I did the first pump.. I agree with JFP in Pa after running the car with the new 71C stat vs. the old 83C stat.. The temp needle now sits just just a hair behind the 180 degree mark after running and letting sit for 25 minutes idling and some minor revving.. It never moved past that mark.. With the old stat the needle sat about 1/4" past the 180 degree mark and would creep up on warmer days.. As I said earlier the old factory pump looked perfect at 91K, so I'm sure the circulation was always there.. I never liked how warm it ran before.
This improvement, I feel, is all T-stat.. More driving to do, but at this point I would recommend the 71C stat.. Inexpensive and really pretty easy to do..
Thanks to all for info and sharing experiences.. Knowledge is power..
03-19-2017, 08:29 PM
#34
+1
JFP has provided much advice to this forum and others. In addition he has answered PM's from me when I first purchased my 986. I respect his knowledge and his generosity.
2004 Boxster S
03-20-2017, 01:10 PM
#35
Probably in a thread but I haven't seen it and seems appropriate here. When replacing the water pump, are you replacing the hoses and flushing all coolant? I'm planning to replace pump and tstat in the next couple of months. See a lot of discussion about that but very little about hoses and actually flushing coolant.
Thanks - Bryan
2001 Boxster base
944 race car
Old Corvette
Random other motorized vehicles
03-20-2017, 03:33 PM
#36
FWIW, I did not observe any signs of needing to replace any hoses or clamps. Neither did I replace the coolant because it was recent.
But do carefully account for all the impeller blades
What is of great value is to remove debris from between the radiators and condensers.
03-20-2017, 04:17 PM
#37
"50 Years of 550 Spyder"
Yes....
....Every four years.
Mileage is NOT the killer. It's the coolant chemically breaking down the impeller plastic over TIME.
I don't understand why this is such a big deal for people to understand.
Just install the lower temp thermostat and slap in a new OEM water pump every four years.
No. Big. Deal.
It's not a Corolla.
EVERY high performance car has "issues" like these. It's the cost of enjoying a bad ass car. Go talk to the BMW "M" crowd or the MB AMG crowd, or talk to the guys whose Corvettes have grenaded on them.
Just budget a new water pump and AOS every four years.
Simple.
03-20-2017, 06:01 PM
#38
you pretty much have to drain out the coolant when changing the WP
are you reusing the drained out coolant?
IMHO that is a penny wise and a pound foolise
