Old 03-06-2011, 05:38 AM   #7
Finally got the outer tie rods changed. Also did the 3 (on each side) rear control arms changed, got the front wheels balanced.
AT LAST - no more vibrations....
Sigh, over the last 5 months, have changed all suspension control arms on all 4 sides, complete M030 suspension upgrade, 2 tie rods, mulitple wheel balancing and wheel alignment + making sure the tire pressures are right...
Phew, the car now is vibration free... it's been a long journey. Only thing left is some adjustment left on the camber... I've got -1.5 degrees, front and back now... didn't have time to get the front reduced..
I still don't know what was the exact cause of the last bit of vibration, as the tie rods seem fine, but the steering feel is completely changed... tight and responsive now.
Also added 7mm spacers to the front as the rims are cayman's and the rears are offset 40 instead of the original 48 (front 55 same as before). Was afraid this might worsen the vibration, but all is fine.
Time to enjoy the car !
shlim8 is offline   Reply With Quote
