Old 08-03-2008, 01:10 AM   #1
If the 3.4 matched the 986's DME (5.2.2 with the same OR 7.2 with the same) ... then the engine would run, rough, but would run.... you would get some noticable power increase, but you would still be running 2.7 timing and etc.... you would need to get the DME flashed by a PST to the 3.4 program
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 08-03-2008, 08:23 AM   #2
you said the 986 3.4L. do you mean the 996 3.4L, or the 987 3.4L? the 987 motor is a no go with your current DME.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 08-03-2008, 02:55 PM   #3
Red face
Oh yes, I mean the 996 3.4L. Thanks.
I've actual done it and it runs. I just don't know if I'm getting the full potential because the DME wasn't upgraded.
02' Seal Grey Mettalic Boxster
www.victoreric.com
victoreric is offline   Reply With Quote
Old 08-03-2008, 02:57 PM   #4
Sorry, but what's PST? Do you know anyone that can do the proper flash? Looks like Softronics is one of them?! Anyone else?
Of if I have access to the DME that the 996 engine came from, will it work if I just used that DME in my Box instead?
www.victoreric.com
Old 08-03-2008, 03:03 PM   #5
The car is running rough and gives 1126, 1128, 1130, and 1133 error codes. Could this be the case? I did a search on the forum for these codes and it mostly relates to MAF or vacumn leak.
Sorry for my ignorance, but what is MAF? and do you think it's actually MAF or because the DME wasn't upgraded?
www.victoreric.com
Old 08-03-2008, 04:05 PM   #6
PST is the Porsche Scanning tool... all dealers and some Indy shops have them.... you need to run a Boxster DME and get it flashed to a 3.4 engine program. The MAF (mass air flow sensor) will need to match that of the same generation of your engine... the tech that does the re scan can tell you if you have the right one or not...
