Old 08-03-2008, 03:03 PM   #5
victoreric
Originally Posted by easyc
If the 3.4 matched the 986's DME (5.2.2 with the same OR 7.2 with the same) ... then the engine would run, rough, but would run.... you would get some noticable power increase, but you would still be running 2.7 timing and etc.... you would need to get the DME flashed by a PST to the 3.4 program
The car is running rough and gives 1126, 1128, 1130, and 1133 error codes. Could this be the case? I did a search on the forum for these codes and it mostly relates to MAF or vacumn leak.
Sorry for my ignorance, but what is MAF? and do you think it's actually MAF or because the DME wasn't upgraded?
02' Seal Grey Mettalic Boxster
www.victoreric.com
victoreric is offline   Reply With Quote
