12-10-2016, 06:50 AM
Engine swap ?
Has anyone here ever done an engine swap in a 1998 boxster ?
I am considering this because of the decreasing availability of 2.5l parts.
Thinking about a complete engine and trans swap to a 3.2l with 6 speed .
Also the car itself is in great shape. Wanting to also get a bit more performance from it.
Thanks,'
Dennis
12-10-2016, 07:53 AM
Sell your car and buy a Boxster S. Swapping is a money losing exercise.
1998 Boxster base in decent shape should bring $6,000-ish. A 2000 Boxster S can be had for $8,500 all day. A Boxster S engine is going to run you $5,000. Plus, while you're at it you will want to replace the intermediate shaft bearing, rear main seal, clutch disk - at a minimum.
Then, you will still have the regular Boxster brakes and not the bigger S/911 brakes, and the other 'S' specific parts.
Good luck!
Dave
Thanks,'
Dennis
12-10-2016, 10:16 AM
Huh? I have two spare engines sitting in my workshop. Each cost less than $2750. Direct swap, no parts need to be moved. 2.5L engines are plentiful, easy, and cheap to find.
Ahh, now we get to the truth!
12-10-2016, 01:40 PM
Personally i think it's cheaper to sell the 2.5 and buy a 3.2.
And if you really want more power there are some V6 and V8 options at the same or much higher costs than a 3.2. Don't forget that you have to adapt and add a lot of parts to put a 3.2 in.
And if you want to stay with a Porsche engine and want to have much more power, than this is the way to go – but for the money you again can buy a much newer car with lots of hp:
Regards, Markus
12-10-2016, 02:54 PM
still plays with cars...
And if you want to stay with a Porsche engine and want to have much more power, than this is the way to go but for the money you again can buy a much newer car with lots of hp:
Regards, Markus
Markus,
Was zum Teufel ist das denn?
Six speed 2000 Boxster S
12-10-2016, 04:41 PM
This is a highly modified M97.90 Mezger Biturbo engine of a 997.1 Turbo in a 987.
More Infos: What did you find on CL today?
Regards, Markus
12-10-2016, 07:47 PM
Interesting. That took a bit of effort. Not sure they have any chance of getting 167k.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
12-13-2016, 10:18 AM
The most practical swap with diy I have seen (& linked ) was Audi V6TT on Piston Heads.
12-13-2016, 11:39 AM
Sell your car and buy mine. I already have a 3.4 in it with a lot of goodies.
12-13-2016, 02:47 PM
Originally Posted by Porsche9
Interesting. That took a bit of effort. Not sure they have any chance of getting €167k.
He would probably need to in order to just break even. We had a customer do a Mezger turbo in a 986; by the time he was done, he had spent more than a new turbo car would cost.
Anything really new is invented only in ones youth. Later, one becomes more experienced, more famous and more stupid. - Albert Einstein
12-13-2016, 03:16 PM
Ben-Auto-Design
Can't say better, JAAY's car is beautiful, fairly priced, and already swapped with a 3.4!
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
12-13-2016, 03:26 PM
Motorist & Coffee Drinker
Very true, and it would be much cheaper to sell the 98 and buy JAAY's car than try to do the swap in a 98.
12-13-2016, 05:17 PM
Porsche "Purist"
Installing an eGas motor in a 98 is quite a task....
But my 3.6 runs great!
1987 924S. 2002 996TT. PST-2
