Old 04-14-2011, 10:01 AM   #1
audisnawb's Avatar
Send a message via AIM to audisnawb
IMS vs IMB replacement
I am having my RMS (rear main seal) replaced and figured I would takle the IMS upgrade everyone is raving about since they have to pull the engine for the RMS.
My question is, I know there is two options here the Intermediate Main Shaft and then just a bearing replacement.
Why would I want to replace the whole shaft, isnt the bearings the problem. I just would like a little advice on how to takle this one.
Thanks guys!
PRESENT:
SUMMER FUN: 1999 986 Porsche Boxster Metalic Black on Sierra Beige
WINTER BEATER: 2007 BMW 530xi
PAST: 2000 986 Porsche Boxster Biarritz White on Sierra Beige
audisnawb is offline   Reply With Quote
Old 04-14-2011, 10:11 AM   #2
Cars built (or with factory engine replacements) after late 2005 require the entire shaft be replaced because of the size of the OEM bearing; this also requires total disassembly of the engine to swap out the shaft. Cars built earlier (with their original engines) only require the bearing be replaced.
Old 04-14-2011, 10:22 AM   #3
audisnawb's Avatar
Thumbs up
Oh thats great news. THANK YOU. Seems like its a little cheaper on the 986 model then
That makes my day!
PRESENT:
Old 04-14-2011, 10:34 AM   #4
Also, there is no reason to pull the engine for the RMS and/or IMS bearing. The transaxle must be removed but these repairs are most often done with the engine still in the car.
Old 04-14-2011, 10:45 AM   #5
audisnawb's Avatar
My car is a 2000 2.7 Tiptronic. The guy told me its 13.6 hours total labor for the RMS and IMS Bearing.... does that sound right?
PRESENT:
Old 04-14-2011, 11:58 AM   #6
Don't have the final bill in front of me but the estimate I received last year was 11 hours: 7 hours for the transaxle removal / reinstall and 4 hours for the IMS update. I believe that included the RMS.
Old 04-14-2011, 12:12 PM   #7
For a Tip, yes; they are a pain in the ass compared to the manual gearbox cars. Some installers prefer to pull the engine and trans out as a unit and then separate them.
Just a thought, if your AoS in not recent, I would have it done at the same time; it is easily accessible with the gearbox out, and if they pull the engine, it is totally out in the open...........
Old 04-14-2011, 12:20 PM   #8
Check the front engine mount and tranny mounts while you're in there...
Old 04-14-2011, 12:38 PM   #9
audisnawb's Avatar
They are charging me (with OEM porsche parts) $1213.57. I thought it was very reaosnable, all things considered.
Thanks for the heads up people.
PRESENT:
Old 04-14-2011, 01:14 PM   #10
husker boxster's Avatar
Hoperfully you're not replacing your IMS with another OEM IMS. The LN Engineering version is what you want to use.
1989 928 S4 5 spd - black
Old 04-14-2011, 01:34 PM   #11
Agreed! That price might be for labor and the RMS but can't include the LN Engineering IMS priced $762.83. https://www.lnengineering.com/ims.html
Old 04-14-2011, 02:48 PM   #12
audisnawb's Avatar
Oh no- as in my original post- Im doing the IMS UPGRADE... I would never replace it with a new "faulty" part lol
PRESENT:
Old 04-14-2011, 03:28 PM   #13
Autobahn Glanz
WhipE350's Avatar
Then that price seems very good.
Old 04-14-2011, 05:18 PM   #14
audisnawb's Avatar
His cost would only cover OEM parts, which is about $200-something
If I were to get my own parts, Id only pay him the labor which is much about 900.00....
PRESENT:
Old 04-14-2011, 05:47 PM   #15
Steve Tinker's Avatar
audisnawb... I'm with Timothy.
Something doesn't add up here.
They are charging you $1213 for the retro fit of the LN bearing kit which costs about $762.
That leaves $451 for 13,6 hours of labour = $33 per hour. Thats seems like a very cheap labour rate !!
I think they are charging you the $1213 for labour ($89-20 / hr which sounds about right) but parts will be on top of that....
Or it could be that the parts are costing $1213 (LN bearing + installation kit + RMS + sundries etc,) with 13,6 hours of labour added to that.
Of course, I could be wrong, but personally, I would confirm with the shop and get a written quote before you get a nasty surprise......
2001 MV Agusta F4.
Old 04-14-2011, 08:40 PM   #16
First off, I was in a hurry earlier and misread the LN Engineering price chart. Their IMS retrofit is either $519 or $595 depending on single vs. double row. The $763 price is for a different kit.
$1213 quoted for labor, RMS, oil fill
$519 (+shipping) for IMS bearing
total = $1732
That's a good price. Feb 2010 I paid $1893.80 (before tax) at my local shop including PCA member discount on labor.
There is also a LN IMS installation tool kit priced $159. Ask if you are expected to supply or will be billed for that.
Old 04-15-2011, 06:14 AM   #17
laphan's Avatar
I just did the LN IMS, RMS and clutch work a couple months ago and the shop charged me 10hrs labor (manual transmission). There should not be any charge on the tools if you do it at the shop listed as LN dealers/installers. The shop did not even charge me for shipping.
I think $1200 for total job sounds very reasonable for tiptronic cars since they might have to remove the engine to do it.
laphan is offline   Reply With Quote
Old 04-15-2011, 06:17 AM   #18
Engine Surgeon
This price is too cheap. I'd be concerned that the work is going to be done thoroughly.
US Patent 8,992,089 &
US Patent 9,416,697
Old 04-15-2011, 09:48 AM   #19
audisnawb's Avatar
His labor is not cheap- 75 an hour which is average for an independant Porsche mechanic. Again- the labor is about 950 and then adding in the parts of the OEM parts, would bring it to the 1200- I am going with the LNengineering double bearing kit for 595- so with the upgraded kit, ill be around 1500
PRESENT:
Old 04-15-2011, 10:41 AM   #20
laphan's Avatar
What parts did your mechanics charge you for $250?
RMS only cost $19.84 (that is the number that I paid 3 months ago, part 997 101 212 01).
Even if you add new AOS, it is only $105 +33 for hose clamp and upper fitting).
