View Poll Results: What's Your Thoughts?
Like it 96 100.00%
Hate it 0 0%
Voters: 96. You may not vote on this poll
Old 03-18-2008, 10:08 AM   #1
Smile Recent Install - DVD Navigation
I recently installed the Avic D3 Navigation with rear view camera in my 2000 Boxster. Still have a few interior upgrades to do but the navigation system install was a success and really made the interior look phenomenal and updated.
What was needed for the job:
T20 Torx Screwdriver
Phillips Screwdriver
A dremel with cutting wheel
A file to sand down rough edges
Electrical tape & Wiring Caps
Wire Stripper
Double Din Kit Includes:
Precision cut fascia (trim) piece in Piano Finish to match Pioneer System
Double Din Housing & Brackets
Double Din Custom Support Bracket for Porsche
Heat Shield, Complete Wiring Harnesses, Antenna Adapter & Radio Removal Keys
Some of the things I really like about my new system is that I know that the install is solid. One of the challenges I noticed other folks had was the weight of the system, and so they elected to have it sit low as possible on the dash. Using the custom support bracket to support the back end of the navigation, and also choosing to mount the double din housing as high up as possible, I was able to keep most of the gap below the system as oppose to the top. And to make sure my stereo stays relatively unaffected by the heat from the climate duct system, I installed a heat shield between the duct and navigation.
The other challenge was that most standard double din navigation systems are a lot smaller than the size of my boxster's opening, so regardless of what I install it was going to make the system appear smaller. Didn't like that look too much, so instead of trying to match up the fascia piece to my car, I went with the piano black fascia piece instead to match it up to the Pioneer system. I think going this route made the fascia piece look like its part of the stereo which gives the illusion that the system is a bit bigger.
Anyways, I posted some of the pics below for everyone to check out!
trieullionaire is offline   Reply With Quote
Old 03-18-2008, 10:18 AM   #2
I think you did a great job. The look of the trim is perfect. How did you get the Porsche crst image on the screen? I like that you added PORSCHE to the bottom of the trim. Makes for a more stock look too. Oh yeah....how much for everything?
1999 Boxster
Triple Black (Basalt metallic)
Silver Carbon Fiber Interior,De-Ambered,Euro LED Taillights, Eibach Pro Kit lowering springs,EuroTech 19" wheels/Kumho tires,Turbo spoiler,Clear halogens
Gemballa red face gauges ..(FOR SALE)
http://i28.tinypic.com/2zzlq29.jpg
986speedster is offline   Reply With Quote
Old 03-18-2008, 11:15 AM   #3
Send a message via Yahoo to Chills
That looks really good. I like your faceplate.
I installed an AVIC-D3 in my '02 BoxS last April. I ended up putting it low in the dash because of the weight.
I have a few questions for you:
How did you make the custom brackets?
What exactly did you use to make your faceplate? I must say it looks much better than mine. I used stretched black vinyl over fiberboard.
Did you install the BT and iPod adapters? I did and the Avic works great with an iPhone.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
Old 03-18-2008, 11:52 AM   #4
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Thats very impressive.
Do the Lights on the Avic D3 match the OEM dash lights? It looks like the D3 is Orange in your pictures just like the Porsche lights. How did you get that?
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 03-18-2008, 02:20 PM   #5
Very nice install. I have a few questions as well since I am putting in a D3 soon too.
I also want to know where you got the double din install kit. Was this made by yourself if yes, any DIY tips?
Did you take any pictures during the install? Any references or links that I can refer to in order to take apart my dash and also to relocate the climate controls to the bottom?
97 Arctic Silver/Boxster Red
Carbon Everything
De-ambered
De-snorkled
Litronics
Eibach Pro Kit
Dansk Sport exhaust
Cheap Chinese headers
Silver console and bumperettes
AVIC D3
15mm H&R spacers in the rear
SSR GT3 19's
GT3 Carbon Replicas
Alcantera door panels
JL Aduio 5 channel powering Polks and Clif Designs
To do/complete:
Elemental Designs 10" subs in fiberglass enclosures behind seats
Carbon 3 spoke install with custom stereo control buttons (tiptronic wheel)
angman is offline   Reply With Quote
Old 03-18-2008, 07:22 PM   #6
Avic Light Settings
Yes you can get your Avic to match any color you want as you can adjust the RGB settings separately to get custom colors. But no, my colors don't currently match, I just kinda was messing around with the settings. Planning on installing blue leds in my instrument gauges and then I will switch my Avic to match.
Old 03-18-2008, 07:39 PM   #7
Looks great, the piano black and the Porsche logo finish it off.
The loo on the screen is a nice touch also.
99 TWIN TURBO Boxster 175k+ miles
Growing up the car magazines said how amazing Porsches are. Was I brainwashed? Somehow...I doubt it.
http://www.pcars.us/albums/10641_porsche_cars.jpg
Gary in BR is offline   Reply With Quote
Old 03-18-2008, 07:53 PM   #8
I did install the Ipod cable and have it routed to the lower storage compartment. Drilled a whole in the back of the storage unit and then slotted out a small circle to pull the cable through. As for the BT adapter, maybe down the road. I am leaning towards it though considering thats another upgrade that will add some modern amenities to the car.
In reference to the support bracket, I had it engineered based on existing mounting points on the boxster. My goal was to make sure the brackets fit tightly with the least amount of modification to the car as possible and that it would provide firm support for the back of the navigation system. The double din housing is strong enough to hold your navi upright if its not stressed but is limited in support especially over time, so the support bracket really helps keep the system from eventually sagging and loosening.
The faceplate is 3/16 thick plastic. But I had it designed to fit very snug to the system and the dash. It's a very tight fit once pushed in place, you would need to remove the left or right side covers to pull the fascia out once it is in.
Old 03-19-2008, 09:56 AM   #9
I put my iPod cable in the same spot, but I didn't drill a hole. The cable actually fits between the lid and the compartment under the hinge.
My whole thing with the install is I wanted to be able to put it back to stock when I sold the car.
Did you design the support brackets yourself? I'm very impressed. You wouldn't happen to have any pictures of the brackets, would you? I made some crude brackets to keep my AVIC in place while sitting on the bottom plate in the dash. I would like the unit to sit centered like yours is.
Again, you did a great job. The best AVIC install I've seen.
BTW, you don't happen to have the reverse cam, do you? My unit came with one and while I've installed it I haven't mounted it anywhere. I can't find a decent place to mount it in the rear of the car.
I bleed green
Old 03-19-2008, 10:23 AM   #10
Well Chills, I must admit that after seeing you do yours, it encouraged me to do mine with a lot of help of course. This forum is great, I learned a bunch since joining.
The custom support bracket that the AVIC sits on was drafted & engineered to fit Porsche. We programmed the layout and ran it on a CNC machine using 18 gauge steel. It turned out awesome, pin point accuracy! We did however place a strip of fuzzy side of velcro on the bracket just like the stock bracket for anti-rattle or knocking. The custom support bracket and the fascia or faceplate will work for Pioneer AVIC-Z2, AVIC-Z1, AVH-P6800DVD and FH-P4200MP as well. My brother who helped me, documented the entire installation with photos & commentaries. He actually ran a production of 100 of these brackets knowing that people would need it for an install of pretty much any 2-din. Hope I answered your question.
Old 03-21-2008, 06:34 AM   #11
HOT DEALS on AVIC D3
http://www.6ave.com/shop/Product.aspx?sku=PIOAVICD3
http://www.pioneerelectronics.com/PUSA/Products/Navigation/In-Dash/2008+Spring+AVIC-D3+%24200+Mail-In+Rebate
Old 03-21-2008, 10:31 AM   #12
So how about some ordering information for that custom bracket that you and your friend machined?
Please PM me if you don't want to post it in the thread.
Thanks, Tri!
I bleed green
Old 03-21-2008, 12:23 PM   #13
My brother is in Miami on vacation, I know he has some left though. He place an order for more. I also know he will have them available soon on Ebay. Everything will be included (the kit 2-din housing, support bracket, heat shield, fascia, wire harnesses, antenna adapter, radio removal key, wire nuts, screws and picture instructions from start to finish) for install, minus the tools & AVIC. I think he also selling some stuff separate in case some people have already done the install but would like a bracket or fascia or faceplate. He's not taking calls till Sunday, but I will get back to you ASAP Chills. Happy Easter!
Old 03-24-2008, 10:18 AM   #14
Cool, all I would need is the bracket and the heat shield. I'll make a new faceplate with the vinyl I've got left over from my current one.
That's a pretty neat idea to put the kit together for Boxster owners. The AVIC is a pretty straight-forward install and looks great in 986s. I hope your brother does well in his venture.
Happy Easter to you too.
I bleed green
Old 03-24-2008, 10:24 AM   #15
Really looking forward to your PDF files. Thank you for working on them and sharing with 986 owners. Also looking forward to this kit that may be for sale.
Carbon Everything
De-ambered
De-snorkled
Litronics
Eibach Pro Kit
Dansk Sport exhaust
AVIC D3
SSR GT3 19's
GT3 Carbon Replicas
To do/complete:
Old 04-27-2008, 08:31 AM   #16
Nice Setup!
DSP and CD holders are currently a problem as I understand it. Any thoughts regarding a timeline for you to have a fix for this?
Great looking stuff!
'00 986 S
FVD Headers
FVD Short shifter
Dansk 100 cell cats
Dansk sport muffler
Upsolute chip
Bilsteins all around
986slover is offline   Reply With Quote
Old 05-01-2008, 05:31 PM   #17
Carbon fiber for the kit coming next week! Aluminum brush finish coming in 2-3 weeks!
Trieullionaire
Old 05-09-2008, 07:34 PM   #18
Done with my install!
I finally finished my install of the Avic D3 and I've gotten so many comments on how cool it looks... One guy wanted to know if there was a kit for his older BMW 5 series!
I also installed a new amp and wow the sound is crisp. The stock tweeter / midrange sounds great with a better amp. I went with new JL audio 6.5 inch subs on the door and now it really booms. The music DVDs really sound awesome!
I'm so glad I went with the Avic D3.
Keep up the good work guys!
One last question. I found in the D3 manual how to upload a picture for the backdrop etc. but I was wondering if you could post the JPG that you used for the Porsche logo. I'd like to get the right size image to make it look just as perfect.
Thanks,
-Steve
chitowndad is offline   Reply With Quote
Old 05-10-2008, 05:43 PM   #19
The carbon fiber faceplates will be available tomorrow on Ebay @ 10pm E.S.T for those who have emailed or PM me. We would have had it on last week but we needed to make some last minute changes. We initially used a computerized CNC router but the outcome wasn't good enough for carbon fiber material. So, we switched to a high powered water jet cutter that was capable of giving us the finish product we were going after. The results proved to be a huge success, wait till you see it! I also wanted to take the time to thank those who have bought a kit directly from my brother or off of Ebay! Well, I hope everyone enjoys the rest of their weekend! C-ya, it's pardee time!
Trieullionaire
Old 05-10-2008, 07:01 PM   #20
can't find it on ebay
can you post a link to were i can find your product on ebay?
amke28m30 is offline   Reply With Quote
HTML code is Off
