03-01-2018, 01:28 PM
#21
Porsche "Purist"
It is a concern, my first motor bent its valves due to stretched chains, but 20,000 miles since the pad replacements on the second motor, it still has about the same deviations.
1987 924S. 2002 996TT. PST-2
03-03-2018, 07:43 AM
#22
Suggest you accumulate a list of to-do issues, drop the engine+trans like New Art suggests.
Much depends on your plans for keeping the car.
For example, with the engine out, you can easily futire-proof the vacuum system,RMS/IMS etc
03-03-2018, 08:56 AM
#23
Artist, 986S tinkerer
+ AOS = piece of cake!
+ that horrible coolant reservoir job = easy peasy!
03-03-2018, 12:14 PM
#24
I just had the transmission out a month ago for a bunch of precautionary stuff: clutch, flywheel, pressure plate, AOS, IMS, water pump, low temp thermostat. So, I wasn't real excited to take the engine out for the cam chain/tensioner pad work. I did remove the 986 airbox in order to replace it with the 987. With the airbox out there is a lot of room on the left side of the engine to do the camshaft removal/reinstall. I think I have a easy solution to the 987 airbox install. I'll post on it if it works out (it's still a work in progress but it's very promising).
03-03-2018, 06:12 PM
#25
Rich
I took out the engine and trans to do mine. I would do it that way again. It wasn't that hard to pull the engine and once out very easy to work on.
03-07-2018, 04:31 PM
#26
To update: I'm in the process of replacing the vario-cam pads. I started with the 1-3 bank as that was the one with the worst cam deviation. I'm doing it with the engine in the car. So far, not a real big deal. The most excitement was taking the header/cat off. I was sure that I was going to break off one or more bolts that attach the header to the head. 0 for 6 on breakage! Used a healthy dose of PB over the course of 24 hours and then used an impact driver. They all popped out intact. I'll replace with stainless steel and high temp anti-seize paste.
The indie that I originally talked to about the cam deviations wasn't too worried and suggested a wait and see approach. One pad was ok. The other was severely worn and crumbled when I pulled it off the vario-cam.
03-07-2018, 05:00 PM
#27
Good on you mate! Good luck on your job. Keep us in the loop!
03-09-2018, 06:26 PM
#28
Now working on 4-6 bank. The cam deviation for this side was 5.3. Since it was within spec (6) I expected the variocam pads to be less worn than on the 1-3 side (7+ cam deviation) that I have already reported on (significant wear). Once again had to remove the header/cat. I thought there was enough room on the 4-6 side that I would not have to remove it. I was wrong. Once again, all bolts came out with a good dose of PB and an impact driver. One of the pads was very worn. Makes me glad I acquired a Durametric when I did and checked the cam deviations. I'm also now a believer in Raby's advice to replace the pads and 4th and 5th timing chains at 40k miles. My 2000 S has 66k miles.
Reason: clarification
