I just had the transmission out a month ago for a bunch of precautionary stuff: clutch, flywheel, pressure plate, AOS, IMS, water pump, low temp thermostat. So, I wasn't real excited to take the engine out for the cam chain/tensioner pad work. I did remove the 986 airbox in order to replace it with the 987. With the airbox out there is a lot of room on the left side of the engine to do the camshaft removal/reinstall. I think I have a easy solution to the 987 airbox install. I'll post on it if it works out (it's still a work in progress but it's very promising).
