Old 12-17-2017, 06:23 AM   #1
since95's Avatar
2000S IMS confusion
Sorry in advance for bringing this up again, but completely confused with info vs what I found in my car.
Info I'm finding states the 2000 could be either dual row or single row. Pulled tranny got to bearing, number on bearing is a NSK 6204DUA17. According to research the 6204 bearing is single row, but depth dimension is 14mm, I measured from the face of the bearing to the part of the center stud pressed into the inner race and I get 20mm... which is close to dimension of double row. My cover is the single o ring seal type with no part number markings on it. I haven't pulled the bearing at this point, don't want it removed and loose while I am ordering replacement.
Anyone help with what type of bearing I have?
I went in due to a pretty good oil leak. Clutch was just starting to kiss the rivets, so I am replacing clutch & all peripherals, flywheel, RMS, and IMS. Car has 97k miles on it & I have no service records. Oil was clean of any kind of debris and motor runs fine, so just piece of mind replacement. Wondering if this is original IMSB.
Sent from my SM-J700P using Tapatalk
since95 is offline   Reply With Quote
Old 12-17-2017, 08:19 AM   #2
It looks like a dual row. As you have the IMS flange cover off, look to see if there is a snap ring between the flange cover and the bearing; if there is, it is a single row. If there is no snap ring, it is a dual row, which uses an internal wire retainer.
Old 12-17-2017, 09:00 AM   #3
since95's Avatar
No snap ring! Thanks for the help.
Old 12-24-2017, 03:58 PM   #4
BirdDog's Avatar
Just to help confirm, that part number (6204DUA17) looks the same as the dual row shown in the first message of this thread...
My IMSB - Story & Pic's
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 12-26-2017, 10:32 AM   #5
since95's Avatar
Bearing was a dual row. I replaced it this past weekend with LN retrofit. Bearing that came out was still in pristine condition, both seals intact, no play, and based on the style of bearing looks to be the factory original, so not bad for 97k miles. Rear main seal went in super easy. Thanks to everyone on the forum who has posted in the past, made both jobs super easy. They were reasonably straightforward for someone who has done some bearing replacements in the past, but always easier when you know what to expect. Built my own cam lock/removal/install/rms tools, but I have precision lathe and mill, so I was able to make them out of extra stock I had around. Still have to install the flywheel/clutch/transmission just waiting on some micro-encapsulated bolts. Winter in New England, so may as well just wait, not doing donuts in the snow with the Porsche, my truck however might be a different story.
Old 12-26-2017, 03:24 PM   #6
thom4782's Avatar
If you still have the old bearing, remove a seal and see if there’s grease on the inside. That will indicate what it’s future would look like
No grease = no future
Old 12-31-2017, 05:05 PM   #7
The number on the seal is not the bearing number, look for the number stamped on the steel rim of the bearing.
the double row ball bearing number is NSK W5204 dims are 20 dia x 47 dia x 23.8 wide
I replaced mine which was in good condition,seals still in place full of oil ,no grease.
I removed the seals in the new bearing to rely on engine oil, 6000km later no problems.
Hope this helps
Tweedboru is offline   Reply With Quote
Old 12-31-2017, 05:59 PM   #8
I just did this. The balls were in nice shape but no grease to be found.
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
Old 05-30-2021, 11:07 AM   #9
pidj's Avatar
So you have to pull the tranny cover off and remove the bearing before knowing what to order from LN?
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 05-30-2021, 12:07 PM   #10
IMS confusion
In short, you have to take it apart to know for sure what you have. The transmission has to come out to know for sure. If it has a deep dish IMS cover it’s single row if it’s shallow it’s dual row. Pat
skypig#232 is offline   Reply With Quote
