The number on the seal is not the bearing number, look for the number stamped on the steel rim of the bearing.
the double row ball bearing number is NSK W5204 dims are 20 dia x 47 dia x 23.8 wide
I replaced mine which was in good condition,seals still in place full of oil ,no grease.
I removed the seals in the new bearing to rely on engine oil, 6000km later no problems.
Hope this helps
