Old 12-17-2017, 05:23 AM   #1
since95
since95's Avatar
2000S IMS confusion
Sorry in advance for bringing this up again, but completely confused with info vs what I found in my car.
Info I'm finding states the 2000 could be either dual row or single row. Pulled tranny got to bearing, number on bearing is a NSK 6204DUA17. According to research the 6204 bearing is single row, but depth dimension is 14mm, I measured from the face of the bearing to the part of the center stud pressed into the inner race and I get 20mm... which is close to dimension of double row. My cover is the single o ring seal type with no part number markings on it. I haven't pulled the bearing at this point, don't want it removed and loose while I am ordering replacement.
Anyone help with what type of bearing I have?
I went in due to a pretty good oil leak. Clutch was just starting to kiss the rivets, so I am replacing clutch & all peripherals, flywheel, RMS, and IMS. Car has 97k miles on it & I have no service records. Oil was clean of any kind of debris and motor runs fine, so just piece of mind replacement. Wondering if this is original IMSB.
Sent from my SM-J700P using Tapatalk
since95 is offline   Reply With Quote
