Old 09-05-2016, 03:18 PM   #1
leaking valve cover repair on '07 CS
While replacing the water pump I was able to take a close look at the oil leak from the bank 1-3 valve cover and it s definitely growing, therefore I decided to fix it the right way.
However I have a couple of questions for the guys that do this kind of jobs regularly, someone like JFP..?
To remove the 1-3 valve cover, it seems that I will only need to lock the cams and remove the header for the 1-3 bank.
Therefore I will need to buy the two green cam plugs, and the exhaust gaskets (header to head and header to cat), is something else that I will need to remove or buy?
Thank you in advance!
Gilles
