Old 09-05-2016, 05:11 PM   #2
JFP in PA
You are going to need more than that. Pulling the valve cover requires the use of a cam holding tool (home brew version in the lower right of the photo, small drawing is the factory tool):
This and the caps need to be installed to hold the cams against the spring pressures while the cover is removed. Without these tools you risk breaking both cams when the cover is removed.
